29253 Discussions
Who is supporting the "6.6C" update to CVF?
lklawrie1
I shouldn't have installed it....
While the new standards checking "may" be okay, the error message I get on the following:
Format(....I2.2)
"The field width is too small for the number of fractional digits"
is unacceptable.
Looking around -- I see the only link to this update is on this forum. Hence my question -- who authored and is supporting this update?
Linda Lawrie
Up to this point, it's the same folks who have been doin CVF all along. There does seem to be a problem in that incorrect diagnostic checks are getting added - this one I know is fixed and yes, another 6.6C update will be out soon (in fact, it may be up on the site Monday.) This is the last one, really, I mean it...
I'll take it as a personal "action item" to get independent review of new diagnostics to prevent further problems such as this one. We apologize for the inconvenience.
lklawrie1
Hey, I'll even try to "test" it on my many lined and moduled source that runs on several compilers -- our release version is CVF.
Linda
Jugoslav_Dujic
Valued Contributor II
If I may suggest naming it 6.0 D? Earlier 6.6C stillborns would certainly create a confusion, especially for you... I can imagine the following scenario in tech support:
- Type "df /what" in the command line. Which version does it give?
- 6.6C.
- Um.... err... which 6.6C?
Jugoslav
It's actually a pain to do that, but I'll see what I can do.
lklawrie1
As I understand this (now), you were asking the forum to more or less preview this modification. As such, I would stick with the 6.6C designation. As I said in the message that started this thread, I could find no evidence of 6.6C except here in your messages (and links).
Linda
Hmm - the I2.2 bug isn't fixed after all. Well, darm...
Sigh. The introduction of the warning bug was a side effect of adding a diagnostic for something like F3.2. The engineer who made the change didn't notice (and we didn't have any tests for this) that it also affected the integer formats.
I have reported this to engineering, but it won't be fixed for CVF.
lklawrie1
Hard to believe that it won't be fixed.
Hopefully, nothing significant is contained in 6.6C but I'll have to warn all my other developers not to switch to it.
Linda
It won't be fixed in CVF because there won't be any more updates to CVF. The bug also appears in Intel Fortran 8.0 and will be fixed in that compiler.
I did add a note about this to the release notes. It is an incorrect standards warning and does not prevent the code from running.
lklawrie1
Yes, but that means a large portion of this particular application cannot use the checkbox "treat standards warnings as errors".
In fact, I had the impression that it was a flat out warning -- not coming from the standards processing. I will check that with the next release of 6.6C.
Linda
No, it's just a standards diagnostic.
I've uploaded a new one here, but at the time of this post, it hadn't been mirrored to the server yet. Should be there soon.
Ok - the "6.6C3" update is available here. It doesn't identify itself as that, but the release notes are dated February and the compiler ident is 6.6-4088-47D3B.
david_jones
Just to note...
(i) I have found2 other incorrect standard-checking messages (having been prompted by the above to try this out for the first time), one a "severe" level message. This is with the above latest version of CVF. Reported tovf-fortran (CVF21515).
(ii) The acknowedgement message (yesterday) does not point to the above version as the latest update, but rather to the one before ....at least the name ends 66C.
I put the "C3" version up for people here to try. I haven't mentioned it to the HP folks yet.
Intel Fortran has the same two standards checking bugs (not surprising)- I've reported them to the appropriate developer. The frst one (line too long) requires that you ask for both standards checking and /extend_source:132, which seems a contradiction to me... The second one has some interaction with the INCLUDE of the affected source - if you compile the source on its own, it's fine.
