For some reason, the compile and build process now takes over 20 times as long to complete as
it did before.
I haven't made any changes to my computer, so I don't see why anything would be different.
The spyware doctor intelliguard is turned OFF, that didn't make any difference, and
I can't see any processes that might rob CPU time from the VS 2008 execuatables.
For example a compile of a short routine takes almost a minute, where it took only a couple of seconds before.
A build takes several minutes now, where it took a few seconds before.
Is there a way to goose up the priority of the VS 2008 executables? Maybe by using the process explorer,
or the task manager?
Both compiles and links are extremely slow.
No network resources.
Always use DEBUG, nothing else.
I always use the DEBUG build, and I don't use any network resources.
That's why this is so puzzling - I've always done it the same way, so I don't see
why the behavior would suddenly be different.
The slowness occurs both with COMPILES and with the linker build.
I'm wondering if there is a "ghost" process somewhere that might be the one that grabs
mt.exe or the EXE I'm trying to build. mt.exe is from an intermediate process in the build.
I have noticed sometimes there are several copies of devenv.exe running at once. Is this normal?
Shouldn't there be just one?
Does your support group use a remote assist? Maybe I should contact them, because
if I upload anything, you won't have the same environment that I do, to test it with.
