29277 Discussions
Why does HPCkit installed on Windows 11, install a 32 bit fortran?
nicholasferguson
Ron_Green
It does not.  the compiler is a 64bit application.  It can create Win 32bit binaries.  Visual Studio configuration default is ia32, so you have to be able to create output 32bit binaries even if our tools are 64bit.   Similar for Linux.  macOS is 64bit only, as Apple dropped 32bit support with Catalina.
nicholasferguson
My bad.  In Visual Studio,I can specify fortan 64....
