29376 Discussions
Why my parallel code by OpenMP is much slower than the sequential code?
Eric_R_
I tried to use OpenMP to parallelize an inner loop. The code is as the following
program test
implicit none
REAL(8)::time1,time2
real(8),allocatable,dimension(:)::b
integer:: k,j,i
j=70000
allocate(b(j))
b=0.0D+00
call cpu_time(time1)
do k=1,40000
 do i=1,j
  b(i)=real(i,kind=8)
 enddo
enddo
call cpu_time(time2)
write(*,*)'The cpu time (s) by the sequential code is',time2-time1
do k=1,40000
 !$OMP PARALLEL DO private(i)
 do i=1,j
  b(i)=real(i,kind=8)
 enddo
 !$OMP END PARALLEL DO
enddo
write(*,*)'The cpu time (s) by the parallel code is',time2-time1
end program test
The file name of the code is 'test.f90'. I built from the command line:
ifort /Qopenmp test.f90
The results are:
The cpu time (s) by the sequential code is   1.98437500000000
The cpu time (s) cost by the parallel code is   3.85937500000000
The parallel code is much slower than the sequential code. Why?
I will greatly appreciate your contribution in this problem.
Thanks a lot.
