Why no bound check within if statement?
Song__James
I found that the compiler does NOT check the bound of an array within if statement. But if you use write statement, it would check.
That is strange.
real stLocalHazard (100)
do iZipIndex =1 , 200
c
if (stLocalHazard(iZipIndex) .gt. 0) then
endif
enddo
andrew_4619
Are you expecting a compile time error for that? If so you are being a bit optimistic to expect the compiler to evaluate the possible run time values of a variable that is used as an array index. Your case is simple but the general case is not and in many cases it would be impossible for the compile to predict. You will get a run time error however.
Much better practice to have say:
do iZipIndex = 1 , size( stLocalHazard)
An then if you change the dimension the code is still good.
Steve_Lionel
How about you post a real, complete program that demonstrates your claim? I tried it and it did check the bounds.
D:\Projects>type t.f90
stLocalHazard = 0
print *, iZipIndex
endif
enddo
end
D:\Projects>ifort /check:bounds t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.0.124 Build 20170811
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.11.25547.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
D:\Projects>t.exe
forrtl: severe (408): fort: (10): Subscript #1 of the array STLOCALHAZARD has value 101 which is greater than the upper bound of 100
Image              PC                Routine            Line        Source
t.exe              00007FF7CE52DB01  Unknown               Unknown  Unknown
t.exe              00007FF7CE521142  Unknown               Unknown  Unknown
t.exe              00007FF7CE56FEB2  Unknown               Unknown  Unknown
t.exe              00007FF7CE570255  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFDC0851FE4  Unknown               Unknown  Unknown
ntdll.dll          00007FFDC098EF91  Unknown               Unknown  Unknown
gib
New Contributor II
It seems (as Andrew infers) that the OP wants the bounds error to be detected at compile time.
Steve_Lionel
I don't think so, at least based on the comment about WRITE statements. A similar test in a WRITE would not give compile-time errors. ifort CAN give a compile-time bounds error, but it requires a constant for the subscript and that's not typical.
Rather, I think the OP saw something, jumped to a conclusion as to what the cause was, and then threw in an uncompilable snippet based on that assumption.
