29253 ディスカッション
Writing <LF> into a data file
Adrian_F_1
ビギナー
2,944件の閲覧回数
I have the following code which is supposed to write a <LF> between two text strings in the output file (which is a CSV file for reading into Excel):
n1 = '"'//trim(ndprops(1))//char(10)//trim(ndprops(2))//'",'
write(csvu,'(a)') trim(n1)
This is so that text too long for a cell is written on two lines into that cell.
However on examination of the file written, I see 0d0a so that an extra <CR> is written to the file, which means the line is read incorrectly into Excel.
How do I tell Fortran not to write the 0d?
0 件の賞賛
20 返答(返信)
Steven_L_Intel1
従業員
2,938件の閲覧回数
Open the file access='stream'. Then only the bytes you write are written. You'll need to write your own record terminators if you want them.
Adrian_F_1
ビギナー
2,938件の閲覧回数
I tried this:
   el = char(13)//char(10)
   open(unit=csvu, file=trim(arg)//'.csv', status='unknown', access='stream', iostat=ierr,err=999)
   write(csvu,'(a)') 'Branch Data'//el
and I got:
forrtl: severe (257): formatted I/O to unit open for unformatted transfers, unit 14, file tee2hor.csv
I guess it's a formatted / unformatted issue?
John_Campbell
新規コントリビューター II
2,938件の閲覧回数
Try:
 write (csvu) 'Branch Data'//el
If that does not work, copy 'Branch Data'//el into a character variable and then write one character at a time.
[fortran]character string*80
string = 'Branch Data'//el
do i = 1, len_trim (string)
 write (csvu) string(I:i)
end do[/fortran]
I have always found reading or writing single characters to stream I/O to have few problems, so I'd expect the first option to work.
stream I/O can be a simple and effective solution, although standard text files for .csv files should be all that is needed.
John
Adrian_F_1
ビギナー
2,938件の閲覧回数
I tried that but I'm still getting 0d0a written to the CSV file instead of just 0a (between brprops(1,i) and brprops(2,i))
          write(csvu) 'Branch Data'//el
          write(csvu) (trim(b1(i)), i=1, nbrprop),'""'//el
where:
          b1(i) = '"'  //trim(brprops(1,i))//char(10)//trim(brprops(2,i))//'",'
jimdempseyatthecove
名誉コントリビューター III
2,938件の閲覧回数
What do you expect when the character stream written is instructed to insert 0d0a?
If you want only 0a, then use only char(10) in one character variable.
Jim Dempsey
mecej4
名誉コントリビューター III
2,938件の閲覧回数
Adrian F: Please see section 9.3.3.4 of the Fortran 2008 standard. Stream files can be opened in formatted or unformatted mode, and the rules governing formatted mode may make it less suited to your needs.
Here is code that works with Ifort, Gfortran and NAG:
[fortran] character*2 el
 character*15 line
 integer csvu
 csvu=11
 open(unit=csvu, file='csvu.csv', status='unknown', access='stream', iostat=ierr,err=999)
 write(line,'(a)') 'Branch Data'//el
 write(csvu)line
 stop
 999 write(*,*)' Error in opening csvu.csv'
 end[/fortran]
Note that the file is opened with FORM='UNFORMATTED' by default when ACCESS='STREAM' is used. To overcome the problem that you encountered by attempting formatted I/O to such a stream, I write to a character variable long enough to hold the output of the WRITE, then I write the character variable to the file.
I realize that making such changes to a large program will involve considerable effort. Please consider whether the RECORDTYPE='STREAM_LF' specifier, used in combination with formatted output, will better serve your purposes.
If I set el = char(10) in the fifth line (not counting the forum-software-donated blank lines) instead, the output CSV file contains no CR characters at all, and that is the behavior that you sought.
Adrian_F_1
ビギナー
2,938件の閲覧回数
you're misquoting me...
I am trying to write string1//char(10)//string2, but I'm getting string1 0d 0a string2 in the data file
el (0d0a) is written at the end of the line
Adrian_F_1
ビギナー
2,938件の閲覧回数
I think the easiest way is to write the file in the normal way and to write some special character instead of char(10) and then to post process the file by replacing all these special characters with char(10)
andrew_4619
名誉コントリビューター III
2,938件の閲覧回数
so as in mecej4's post where he has:
write(line,'(a)''Branch Data'//el
you should put
write(line,'(a)''a string'//char(10)//'another string'//char(13)//char(10)
mecej4
名誉コントリビューター III
2,938件の閲覧回数
I have used that artifice several times in the past for writing CSV files-- not  for use in Excel but for inputting data to an SQL database. You will have to choose a special character, such as '$', which you can be reasonably sure to not occur in any of your string data. Utilities such as tr can do the routine transliteration for you, but context-dependent substitutions will need more work by the user to ensure that incorrect and irreversible substitutions are not made.
Adrian_F_1
ビギナー
2,938件の閲覧回数
Now I'm confused.  I am writing '#' into the output file where I eventually want char(10).  After I'm finished writing the file, I execute the following code to read from this file one char at a time and write into the new file, substituting '#' with char(10):
        ll = len_trim(fil)-1
        open(unit=csvu, file=trim(fil)     , status='unknown', access='stream', iostat=ierr,err=999)
        open(unit=csvv, file=fil(1:ll)//'v', status='unknown', access='stream', iostat=ierr,err=999)
        do while (.not. eof(csvu))
          read(csvu) c1
          if(c1 == '#') c1 = char(10)
          write(csvv) c1
        enddo
        close(unit=csvu)
        close(unit=csvv)
However when I look into the new output file I still see 0d0a instead of just 0a !  Where is this other 0d coming from ??
mecej4
名誉コントリビューター III
2,938件の閲覧回数
It is hard to say, without seeing the hex-dump of the input file. I tried your code on an input file, x.csu, with the following contents:
[bash]s:\lang>xxd x.csu
0000000: 4272 616e 2368 2044 6174 610a 200a       Bran#h Data. .[/bash]
Here is the dump of the output file (on Windows 8.1-64):
[bash]s:\lang>xxd x.csv
0000000: 4272 616e 0a68 2044 6174 610a 200a       Bran.h Data. .[/bash]
[bash]s:\lang>fc/b x.csu x.csv
Comparing files x.csu and X.CSV
00000004: 23 0A
[/bash]
Adrian_F_1
ビギナー
2,938件の閲覧回数
The two files are attached.
mecej4
名誉コントリビューター III
2,938件の閲覧回数
The input file tee2hor.txt has <CR> characters in it. I removed them using the dos2unix utility that is available for Cygwin, and ran the program that you listed in #12 on it. I found that the output file had all instances of '#' replaced by <LF>, and there were no <CR> characters in the output file. Thus, everything appears to be in proper order.
Adrian_F_1
ビギナー
2,938件の閲覧回数
I'm not sure which <CR>'s you are seeing.  It is the # between say "defined" and "start node" (ie. defined#start node) which I'm trying to replace by <LF>.  tee2hor.txt has the #.  I'm not talking about the <CR><LF> at the end of the line.  Those are the only <CR> in the file.  eg. The first line of tee2hor.txt looks as follows:
"  number","  name","  type","defined#start node","defined#end node","flow#start node","flow#end node","roughness#(mm)","length#(m)","diameter#(mm)","kfitting#method","fitting#k1","fitting#kinf","angle#(deg)","Darcy#fric factor","inlet#pressure (bar)","outlet#pressure (bar)","inlet#temperature (C)","outlet#temperature (C)","friction#velocity head","fittings#velocity head","momentum#velocity head","density#(kg/m3)","viscosity#(cP)","heat cap#(kJ/kgK)","velocity#(m/s)","Reynolds#number","flowrate#(kg/s)","frictional#deltap (bar)","elevational#deltap (bar)","tee#deltap (bar)","total#delta p (bar)","flow#direction","tear#branch","spec#type","  text",""<CR><LF>
I'm looking to replace all the # in the line by <LF> by my code.  I have attached the output file created by my code which as you can see has <CR><LF> where the #'s were
Adrian_F_1
ビギナー
2,938件の閲覧回数
Actually I just looked at the output file using XXD and it does have the <LF> only, it must be my editor (Crisp) which is adding the <CR> !
Anyways, that said, when I try to import this output file into Excel, I still have the same problem that the items separated by this <LF> do not appear on separate lines in the same cell.  In fact the second bit after the <LF> is ignored and not imported.
Any idea How I can get, eg.
defined
start node
in one cell?
andrew_4619
名誉コントリビューター III
2,938件の閲覧回数
This program forms the output with LF and CR in the correct places, I tested with excel 2003? [fortran]    program Console3
        implicit none
        character(len=64000)         :: gbuf
        integer                      :: ip, istat
        character(len=256)           :: gstuf
        ip=1
        gstuf='Branch Data'
        call addstring(gbuf,ip,gstuf,2)
        gstuf='"  number","  name","  type","defined'
        call addstring(gbuf,ip,gstuf,1)
        gstuf='start node","defined'
        gstuf='end node","flow'
        gstuf='start node"'
        gstuf='1,"B1","PIPE","N1","N3","N1","N3",  0.45700000E-01,   100.00000    ,   100.00000    ,1,   0.0000000    ,   0.0000000    ,  0.000,'
        open(10,file='fred.csv',status='unknown',access='stream',iostat=istat)
        if(istat /= 0) write(*,*) 'open error'
        write(10,iostat=istat) gbuf(1:ip-1)
        if(istat /= 0) write(*,*) 'write error'
        close(10,iostat=istat)
        if(istat /= 0) write(*,*) 'close error'
        write(*,*) 'Finished'
    end program Console3
    subroutine addstring(gbuf,ip,gstuf,ifl)
        character(len=2),parameter   :: LF=char(10)
        character(len=2),parameter   :: CR=char(13)
        character(len=2),parameter   :: CRLF=char(13)//char(10)
        character(len=*), intent(inout) :: gbuf
        integer, intent(inout)          :: ip
        integer, intent(in)             :: ifl
        character(len=*), intent(in)    :: gstuf
        integer                         :: ilen
        ilen=len_trim(gstuf)
        gbuf(ip:ip+ilen-1)=gstuf(1:ilen)
        ip=ip+ilen
        if (ifl==2) then
            gbuf(ip:ip)= CR
            ip=ip+1
        else
            gbuf(ip:ip)= LF
            ip=ip+1
        endif
    end subroutine addstring[/fortran]
andrew_4619
名誉コントリビューター III
2,938件の閲覧回数
That was the output in excel attached (screen grab)
Adrian_F_1
ビギナー
2,938件の閲覧回数
I ran your program above and it created the fred.csv attached (I had to rename to .txt as the forum's uploader wouldn't allow.csv files ??).
Then I imported into Excel 2010, but I still have the same problem, see attached screen capture.
Adrian_F_1
ビギナー
2,819件の閲覧回数
Actually it does work, just that you have to turn on Word Wrap in Excel!  My original format worked too...
返信
