Wrong Path in compilers.sh
Vincent_J_
Hi all,
I have struggled setting the DYLD_LIBRARY_PATH in OS X El Capitan with the las install of ifort in command line only.
There seem to be a mistake in the installation directories : "/opt/intel//" instead of "/opt/intel/". This error was found in compilevars.sh as well as in mklvars.sh.
Vincent
Kevin_D_Intel
Hi Vincent. Sorry to hear about the struggle. Just to confirm that I'm reading your post correctly. Did you find this with our most recent PSXE 2016 Update 2 release for OS X?
Vincent_J_
Hi Kevin, I used the online installer. ifort --version just gave me :
ifort (IFORT) 16.0.2 20160204
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
Regards, Vincent
Kevin_D_Intel
Thank you. That is our latest Update 2. I'll look into this and update after I know more.
Kevin_D_Intel
I reproduced/confirmed the extraneous slash in the PROD_DIR setting is a defect and escalated the matter to our developers. Thank you for reporting this.
(Internal tracking id: DPD200411070)
