I'm using ifort version 17.0.0.
The following code gives a forrtl: severe (71): integer divide by zero error if the object has no component.
Just uncomment the component definition in the EmptyType specification and the error magically goes away.
! ifort -coarray -coarray-num-images=1 main.f90; ./a.out Module EmptyType_Module Type :: EmptyType ! integer :: idum End Type End Module Program Main use EmptyType_Module ,only: EmptyType type(EmptyType) ,allocatable :: Object[:] allocate( Object
We'll take a look - thanks.
Escalated as issue DPD200416771. This thread will be updated with any progress. Thanks for the nice test case.
Topic Options
