Wrong error when the actual argument of a procedure is a coarray component
FlyingHermes
The following code generates a compile-time error but I think the code is correct.
Here is the code:
Program Main
  implicit none
  Type :: MyType
    real(8) ,allocatable ,codimension[:] :: CoVar
  End Type
  type(MyType)  ::      Object
! The following line cause a compile-time error with ifort version 15.0.4
  Object%CoVar       =       CoMinVal( Object%CoVar )   ! main.f90(12): error #8396: If the dummy argument is a coarray, the corresponding actual argument must be a coarray and must have the VOLATILE attribute if and only if the dummy argument has the VOLATILE attribute.   [COVAR]
  associate( CoVar => Object%CoVar )
   CoVar        =       CoMinVal( CoVar )
  end associate
  contains
  Pure Function CoMinVal( CoVar ) result(VarMin)
    real(8) ,codimension
  • ,intent(in) :: CoVar real(8) :: VarMin integer :: iImg VarMin = CoVar do iImg = This_image()+1,Num_images() VarMin = min( VarMin, CoVar[iImg] ) end do do iImg = 1,This_image()-1 VarMin = min( VarMin, CoVar[iImg] ) end do End Function End Program
  • and the compilation output is:
    $ ifort -v && ifort -coarray main.f90
    compilation aborted for main.f90 (code 1)
    Note that a workaround consists of using an associate block
    FlyingHermes
    Any updates on this one ?
    Steven_L_Intel1
    Sorry, looks as if we overlooked it. I see it still fails in 17.0.1 and will report it to the developers tomorrow.
    Steven_L_Intel1
    Escalated as issue DPD200416774 - sorry for missing this.
