29285 Discussions
-Wsurprising warning for overloaded intrinsic size
FilippoMonari
Hi all,
I am in a software package submission process, and when I undertake it I get the following warning that prevents me to complete it:
use numbers_utils
      |      1
Warning: Type specified for intrinsic function ‘size’ at (1) is ignored [-Wsurprising]
In particular, I have overloaded the intrinsic function "size" in the module "types", that I import into  "numbers_utils". The definition of the overloaded interface follows:
interface size
  module procedure number__size
  module procedure graph__size
end interface size
pure function number__size (x) result(sz)
  implicit none
  type(number), intent(in) :: x
  integer :: sz
  sz  = 0
  if (is_allocated(x)) sz = product(x%shp)
end function number__size
pure function graph__size (x) result(sz)
  implicit none
  type(graph), intent(in) :: x
  integer :: sz
  sz = 0
  if (is_allocated(x)) sz = size(x%nodes)
end function graph__size
I am compiling with "gfortran" version 7.5.0 on Ubuntu 18.04, and am not able to reproduce the warning on my environment and not even a couple of VM that I have running on AWS. The submission process runs on a Debian server. As quick fix I will avoid the overloading which I think it is what is causing the problem. However I would be glad if someone could point me towards the actual cause of this warning, so as to correctly write the overloaded interface in the future.
mecej4
Your question is about a gFortran compiler option. Intel Fortran does not have that option. Please ask in an appropriate forum.
mecej4
