29390 Discussions
a bug of intel fortran compiler?
lauhwa
Recently I have tried to use "block/end block". But I found a error when I wrote some data as follow
program main
    implicit none
    integer::i
    i=1
    write(*,*)i,'0'
    block
        integer::j
        write(*,*)j,'1'
        write(*,'(<i>i8)')j
    end block
end program
then, the fortran compiler return an internal error:
fortcom: Fatal: There has been an internal compiler error (C0000005).
while if I don't use block or replace "<i>I8" by 1I8, no error reported.
The fortran compiler is Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.5.281 Build 20190815 with a student license.
andrew_4619
ICE is a compiler bug always but your code is not standard Fortran, the <i> syntax is an extension supported by some compilers. You should not use that '(*(i8))' would be any number or you could build a format at run time.
character(20) :: gf, gtmp
integer :: i
i = 2
write(gtmp,'(i0)' ) i
gf = '('//trim(gtmp)//'(i8))'
write(*,gf) i
andrew_4619
integer :: i
i = 2
write(*,gf) i
lauhwa
Think you so much! It is better and common way.
Steve_Lionel
If you want the format to be repeated as many times as there are items or elements, then use the format:
'(*(i8))'
