29279 Discussions
activating evaluation license on Mac Snow leopard
sunil_iitmadras
Hi!
I downloaded the evaluation version of the fortran composer from intel site and installed it on my Mac running OS 10.6.4 . I copied the license file sent by intel onto my computer. But I get the following error after typing "ifort"
"ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 1). Trusted Storage based license could not be supported"
what should I do ?
thanks
Sunil
Kevin_D_Intel
You didn't specify, so if you did not, please place (as root) the license file you received into this location on your system:
/Users/Shared/Library/Application Support/Intel/Licenses
And set permissions to include group/other "read" (i.e. use file mode bits of at least "644")
