29616 Discussions
adjustable array as a formal parameter
dnoack
I would like to give anarray as a formal parameter to a subroutine in the following way
subroutine sub(b)
double precision, dimension(:) :: b
write(*,*) b
end subroutine sub
program arrayDelivery
double precision, dimension(3) :: a
a=987654.321
call sub(a)
end
Althoughifort compiles the code without any errors,the program does not deliver the correct results. Instead of the values for b it prints only a blank line. I think, that the delivery of the formal parameter is not correct.
Please can anyone explain to me the reason.
dino
That's not an adjustable array (where you would pass the bound as a separate parameterr and declare it in the subroutine as a(n)), it's an assumed-shape array and an explicit interface is required to be visible to the caller. If you make sub a "contained" procedure of the main program, that would do it, otherwise sub needs to be in a module or you have to write an INTERFACE block.
