array initialization
Roman1
When I compile the following program using the Intel Fortran compiler,
there are no error or warning messages printed. However, I think the code
has a bug because a 2D array is initialized with a 1D array.
[fortran]program test_array
implicit none
integer:: a(2,2) = (/ 1, 2, 3, 4  /)   !!!
print*, sum(a)
stop
end program test_array
[/fortran]
Roman
This code is legal and standard Fortran. The standard (F2008) says:
"... if necessary, the value is converted according to the rules of intrinsic assignment (7.2.1.3) to a value that agrees in type, type parameters, and shape with the variable."
Then 7.2.1.3 says:
"If the variable is an array, the assignment is performed element-by-element on corresponding array elements of the variable and expr."
This is a bit looser than if you had an actual assignment statement but matches what a DATA statement can do.
Roman1
Thanks for the reply.
The reason for the question is that when I compiled the same code using gfortran, I got the
following error:
Error: Incompatible ranks 2 and 1 in assignment at (1)
So perhaps, there is a problem in gfortran.
Also, the Intel compiler does issue a warning if parameter is used.
[bash]integer,parameter:: a(2,2) = (/ 1, 2, 3, 4  /)   !!!
[/bash]
warning #6366: The shapes of the array expressions do not conform.
The warning for the parameter is correct.
