I use ifort version 12.1 fromcomposer_xe_2011_sp1.6.038 on mac osx 10.6.8. I am trying to compile an ocean circulation model (UVic_ESCM), which did work with a previous version of ifort (11.1.058). With the new ifort version, however, I got a segmentation fault, which I could not debug. I think this is a compiler bug, but maybe the problem is somewhere else.
The segmentation fault occurs only with compile options -O2, -O3, of -fast but not with -O1. Using the option -check bounds prevents the segmentation fault but the executable is very slow.
I have trimmed down the subroutine where the error occurs as much as possible (files testsolv.f and solve.f). The file tstslv is a bash shellscript compiling and running the test files. Adding a line with a WRITE command in the inner loop in solve.f also prevents the error, even when inside an IF statement preventing the WRITE from being executed (see inside the file solve.f).
This option -mp1 hasn't been well supported for several years, since the superior replacement options were instituted. I doubt it was ever tested on osx. It's not really a compiler bug when you use unsupported options which happen to remain available.
Applications which required -mp1 under ifort 9.1 and earlier might wish to use options
-assume protect_parens -prec-div -prec-sqrt
or options such as -fp-model source and -standard-semantics might be useful.
I haven't been able to reproduce your problem; I don't have osx available.
Thank you. I was able to reproduce your problem with our latest Mac compilers. I have started a new internal tracker DPD200230196, and we will keep you updated about any developments.
Best!
-Udit
NB. I could reproduce your problem without the -mp1 flag. Can you confirm that?
Best!
-Udit
Thank you very much for your quick reply. Yes, the error occurs with and without the -mp1 flag.
Best,
Markus
Sounds good. We're now starting to work on it.
Best!
-Udit
Best!
-Udit
Are there any new developments on this bug?
Markus
I believe work is still ongoing on this bug. Short of putting an exact time frame on when the defect will be fixed, I can say that its priority is high.
Best!
-Udit
Best!
-Udit
I believe that this bug will be fixed in Update 9, scheduled for February.
