29276 Discussions
ascii character constant used as a select-case-value
riad_h_1
for some characters (in fact, those with ascii codes greater than 127), I observe different results depending on whether an `if-else` or a `select case` is used. Here is a minimal example that reproduces the issue:
use iso_fortran_env
implicit none
integer,                     parameter :: ascii = selected_char_kind ("ascii")
character(kind=ascii,len=1), parameter :: C1 = achar(128)
character(kind=ascii,len=1)            :: myc = C1
print*,'1) With select case:'
select case ( myc )
case ( C1 )
   print*,'   myc = C1'
case default
   print*,'   myc /= C1 (problem!)'
end select
print*,'2) With if-else:'
if ( myc == C1 ) then
   print*,'   myc = C1'
else
end if
end
When compiled with ifx 2024.1.2 I get:
 2) With if-else:
    myc = C1
No problem observed:
- when C1 = achar(from 0 to127).
- with other compilers (ifort, gfortran, nagfor)
Steve_Lionel
I can easily reproduce this. Looking at the run-time assembly code I see this:
The movsx does a sign-extended move of myc into register rax. The code then subtracts 128 and does a branch-if-equal to the C1 case. The problem is the sign extension, which should not have been done for a character value, messing up the compare. Compiler bug.
What's REALLY strange to me, though, is that if I ask for an assembly listing, I see different instructions. movsbq would be correct here. I'm not sure why the sub is in the assembly listing as subq, as that does not seem to be a valid mnemonic.
	movsbq	_UNNAMED_MAIN$$$MYC(%rip), %rax
	subq	$128, %rax
	je	.LBB0_2
	jmp	.LBB0_1
Xiaoping_D_Intel
A bug report has been opened. We will fix it in the future product.
Regarding the different instructions showed in the VS debugging window and asm listing it is because by default ifx will generate the assembler output file in AT&T* syntax which is different from the Intel syntax in the debugging window. On Linux it can be changed with "-masm=intel" option.
Steve_Lionel
Thanks, but that should not change the movsx to a movsbq, an entirely different instruction. If it had actually generated movsbq, the bug would not be there.
Xiaoping_D_Intel
Hi Steve, in AT&T* syntax "movsbq" is the same instruction as "movsx" in Intel syntax. I found a online doc https://docs.oracle.com/cd/E53394_01/pdf/E54851.pdf which provides the mapping between these two sets of mnemonics. (movsbq is at page 38).
Steve_Lionel
Ah, ok. I was looking at a different reference. In that case, both movsx and movsbq are wrong in the generated code.
