29360 Discussions
ifx Internal Compiler Error with -heap-arrays option
lauvergn
I’m compiling a library, https://github.com/lauvergn/AD_dnSVM (see the zip file) and I’m getting an Internal Compiler Error when I’m using the  -heap-arrays option with ifx.
The following combinations (ifx/ifort -O/-O0 …) give:
ifx -O -heap-arrays : ICE (error #5633: **Internal compiler error) while compilling SRC/ADdnSVM/dnVec_m.f90
ifx -O0 -heap-arrays : Compilation OK, execution ERR (on the Test_dnS.x test)
ifort -O -heap-arrays : Compilation + execution OK
ifort -O0 -heap-arrays : Compilation + execution OK
ifx -O : Compilation + execution OK
ifx -O0 : Compilation + execution OK
ifort -O : Compilation + execution OK
ifort -O0 : Compilation + execution OK
To reproduce the errors:
make FC=ifx OPT=1 ut
or
make FC=ifx OPT=0 ut
I’ve tried to reduce the library size without success.
PS: I'm using the Intel Fortran Compiler (IFX) version 2023.1.0 (I don’t have access to a more recent version) on a linux distribution.
TobiasK
@lauvergn
seems to work with the internal build that will be 2025.0:
***********OS:      Linux
***********COMPILER:   ifx
***********COMPILER_VER: ifx (IFX) 2025.0.0 20240825
***********OPTIMIZATION: 1
***********OpenMP:    1
***********INT:     4
***********LAPACK:    1
***********FFLAGS:    -O -g -traceback -heap-arrays -module OBJ/obj_ifx_opt1_omp1_lapack1_int4 -IOBJ/obj_ifx_opt1_omp1_lapack1_int4 -qopenmp -cpp -D__LAPACK="1"
***********FLIB:     -qmkl -lpthread
***********ext_obj:   _ifx_opt1_omp1_lapack1_int4
echo "dnVec compilation: OK"
TESTING dnS module. Number of tests  :95
TESTING dnS module. Number of error(s):0
TESTING dnPoly module. Number of tests  :15
TESTING dnPoly module. Number of error(s):0
TESTING dnVec module. Number of tests  :10
TESTING dnVec module. Number of error(s):0
 done with the unitary tests
***********COMPILER:   gfortran
***********COMPILER_VER: GNU Fortran (Ubuntu 13.2.0-23ubuntu4) 13.2.0
***********INT:     4
***********FFLAGS:    -O5 -g -fbacktrace -funroll-loops -ftree-vectorize -falign-loops=16 -JOBJ/obj_gfortran_opt1_omp1_lapack1_int4 -IOBJ/obj_gfortran_opt1_omp1_lapack1_int4 -IExt_Lib/QDUtilLib/OBJ/obj_gfortran_opt1_omp1_lapack1_int4 -fopenmp -cpp -D__LAPACK="1"
***********FLIB:     -llapack -lblas
***********ext_obj:   _gfortran_opt1_omp1_lapack1_int4
***********QD_DIR:    Ext_Lib/QDUtilLib
Devorah_H_Intel
The latest 2024.2.1 ifx is available for download FREE from here
lauvergn
I'm afraid, the problem with the **heap-arrays** option is still present with the version 2024.2.1 (20240711).
However, the error is only at the execution. There is no more "Internal Compiler Error":
ifx -O -heap-arrays : Compilation OK, execution ERR (on the Test_dnS.x test)
Remarks:
- the errors in Test_dnS.x are not at the same line with the option -O and -O0
- With ifort, everything is running fine.
TobiasK
@lauvergn
just a clarification. By execution error you are referring to the unit tests that are run after compilation automatically by make?
lauvergn
Yes. I've got an error during the run of the first test just after the compilation.
The first executable is: Test_dnS.x
TobiasK
@lauvergn
***********INT:     4
***********INT:     4
lauvergn
Great. Thanks, I'll wait for this version.
