can i delete some procedures from the generic binding list which inherits from the superclass
Li_L_
it seems a quite simple question but i can't find an explicit answer...
someone knows that? how to do it?
IanH
If type `sub` is an extension of super, then it is supposed to be able to be treated as an object of type `super`.  An object of type `super` has a accessible generic binding that has the characteristics of the `f2` specific binding, so an object of type `sub` is also required to have such an accessible binding.  The language rules enforce this.
Remember that if the parent type of an object is accessible and not abstract, you can always access the object as if it was of the parent type by using the parent component `s%super`.  Even if the parent type is abstract you can also pass an object of type `sub` to a procedure that takes a polymorphic argument of type `super`, so the ability to hide a particular specific binding from a generic for references via an object of the declared type of `sub` would be pretty "weak".
Perhaps you need a different type hierarchy - perhaps `sub` is not an extension of super, but both `sub` and `super` are extensions of some third type that does not have the specific binding that you want to remove.
An impure elemental procedure can contain a stop statement.
FortranFan
More informed readers of the standard can give you a better answer, but see this thread:
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/681705
Those procedures bound to the superclass on the generic list that have the PRIVATE attribute seem to be inaccessible outside the module containing the superclass, if I understand the Fortran 2008 interp 052 correctly.  So making use of the PRIVATE attribute in conjunction with placing the inherited class is another module might give you what you're looking for.
I don't know but other than  the above possibility, it appears one can only OVERRIDE.
Li_L_
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux...
i tried, but i failed
module super_
implicit none
    private
    public::    super
    type:: super
    contains
        generic::           g   => f1,f2
        procedure::         f1
        procedure,private:: f2
    end type super
contains
    function f1(this)
    class(super):: this
    integer(4)::    f1
        f1 = 1
    end function f1
    function f2(this,a)
    class(super):: this
    integer(4)::    f2,a
        f2 = 2
    end function f2
end module super_
module sub_
use super_
implicit none
    type,extends(super):: sub
    contains
    end type sub
contains
end module sub_
program test
use sub_
implicit none
type(sub):: s
    print*, s%g()
    print*, s%g(2)
    print*, s%f1()
    !print*, s%f2()
end program
private attr just prevent the use of f2 directly , but i access f2 with the generic procedure
actually i tried disable the f2 in subclass by overloading. but i can't write a 'stop' statement when i want f2 be an elemental procedure
so another question, how can i disable f2 efficiently without losing the elemental attr
IanH
Li_L_
that's the exact answer i want. thanks!
