can't install
legoses
When I try to install the compiler I get the message: "Software setup assistant was unable to create the license folder"?? Any ideas
TimP
Quoting - legoses
Are you installing as root? In that case, the compiler would create (if necessary) /opt/intel/licenses/ in order to copy the license there. You can do the same with the license file yourself, in which case the setup assistant should offer to use it.
legoses
Quoting - tim18
I created that folder and placed the license file in there. No change. I have admin on this machine? My research advisor bought the compiler and then when I went to download it I used my email address. I don't think this would cause any problems. Do you
Ron_Green
Quoting - legoses
There is not enough information here. Is this Linux (what distro and version) or Mac OS X (version)?
What is your package name?: should be something like l_cprof_p_11.1.038 or m_cprof_p_11.1.046
If linux, as the user you use to install the compiler can you:
touch /opt/intel/licenses/foo
or do you get a permissions error?
If Mac OS X:
touch /Users/Shared/Library/Application Support/Intel/Licenses/foo
or do you get permissions error?
