Comunicados
cannot build an x64 fortran program
yi_g_
Principiante
2.507 Visualizações
Hi, my os is win10 and I have intel parallel studio xe 2016 cluster edition and vs2015 professional edition installed. Now I want to build an x64 fortran code, in build--configuration manager, I have set the active solution platform to be x64. However after building, I got "fatal error LNK1104: cannot open file 'ifconsol.lib'", while building a win32 code shows no such error. What might be the problem? Thanks.  Attached please find my configuration.
11 Respostas
Kevin_D_Intel
Funcionário
2.507 Visualizações
Perhaps you didn't install the 64-bit compiler/library components?
Do you have an ifconsol.lib under a path: C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016\windows\compiler\lib\intel64_win ?
If not then via Control Panel, use Uninstall/Change for Intel Parallel Studio XE 2016, select Modify, and then step through the menus making certain when you see the Architecture pane that both IA-32 and Intel(R) 64 are checked. Click next and check under the Intel Visual Fortran component (click the "+" plus symbol to expand) that both IA-32 and Intel(R) 64 are checked to be installed and proceed with the installation.
yi_g_
Principiante
2.507 Visualizações
I do have the intel64 architecture installed and the above mentioned folder and file both exist.
Kevin_D_Intel
Funcionário
2.507 Visualizações
Ok. Please attach a build.log and your Fortran project's .vfproj file.
yi_g_
Principiante
2.507 Visualizações
Attached please find the buildlog and .vfproj file, thanks.
Kevin_D_Intel
Funcionário
2.507 Visualizações
Ok, thank you. Can you please next set, Properties > Linker > General  > Show Progress to Display Some Progress Messages (/VERBOSE:LIB)
And then rebuild the x64 configuration and provide the build log for this. I would actually like to see this verbose output for both the x64 and win32 configuration builds.
Is your Intel Parallel Studio XE 2016 also installed on the D: drive?
yi_g_
Principiante
2.507 Visualizações
Attached please find the new buildlog after setting /VERBOSE:LIB and indeed the intel parallel studio xe 2016 is installed on the d: drive. If I set the active solution platform to be x86, then the buildlog is also attached, which is named as buildlongw32.
Kevin_D_Intel
Funcionário
2.507 Visualizações
Thank you. VS is not giving me what I want.
Can you compare the values set in the Libraries field setting for the x64 tab under Tools >  Options > Intel Compilers and Tools > Visual Fortran > Compilers  to those shown below.  You will notice there is a tab for Win32 and x64.
The values for Libraries under x64 should be like:
$(IFortInstallDir)compiler\lib\Intel64_win
$(IFortInstallDir)mkl\lib\Intel64_win
$(VCInstallDir)atlmfc\lib\amd64
$(VCInstallDir)lib\amd64
$(WindowsSdkDir)lib\winv6.3\um\x64
$(UniversalCRTSdkDir)lib\winv10.0\ucrt\x64
$(UniversalCRTSdkDir)Lib\$(UCRTVersion)\ucrt\x64
If you are not seeing values like this then press Reset on this pane, check the values again, and if they compare then try x64 build again.
yi_g_
Principiante
2.507 Visualizações
Thanks, Kevin, problem solved. The libraries for x64 are not those as you mentioned and after I reset their values, now I can build x64 project, thank you again for your help.
Kevin_D_Intel
Funcionário
2.507 Visualizações
Great! I appreciate your patience with the numerous requests and am glad we resolved this.
I'm also just curious, did you have any earlier version of Parallel Studio XE installed on the system before this current version?
yi_g_
Principiante
2.507 Visualizações
No. In fact, recently I downloaded and installed ms-mpi. In order to include the mpi library, I erroneously changed the library path for x64 and I did not even remember it, that's why I cannot build x64 code.
Kevin_D_Intel
Funcionário
2.507 Visualizações
Ok, thank you, that’s settling.
Responder
