catastrophic error using automatic arrays in module procedure declarations (in interface block)
zp3
Hi I'm getting a catastrophic error when trying something like this:
module foo_mod
    interface
        module subroutine foo(lb,v)
            integer(IK), intent(in) :: lb
            real(RK), intent(inout) :: v(lb,:)
        end subroutine foo
    end interface
  contains
    module procedure foo
    end procedure foo
end module foo_mod
I'm using ifort 16.0 beta. This problem looks somehow critical to me because the method above seems to be the only way to pass the lower bound of an array slice from a caller to a subroutine.
Thanks!
zp3
Thanks!
