29258 Discussions
catastrophic error with Intel Fortran 17.0.0.098
luiceur
I just wanted to report this compilation error that I get compiling fortran coarray code with intel 17.0.0.098
ftn -c -assume realloc_lhs -coarray=shared -debug full -traceback -free -fPIC -warn all -O2 -qopt-report  cgca_m3gbf.f90
ifort: remark #10397: optimization reports are generated in *.optrpt files in the output location
cgca_m3gbf.f90(119): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for cgca_m3gbf.f90 (code 1)
This is not the case with Intel 16.0.2.181, which compiles without any problems
Luis
mecej4
You may try updating to 17.0.1, which was released recently. If you want the problem investigated further, please provide the source code for cgca_m3gbf.f90 (or a link to it).
Kevin_D_Intel
Same issue reported earlier here, https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/660230. The issue is fixed in the 17.0.1 update.
