29275 Discussions
catastrophic error with ifort 19.1.2.254
ccorrado
I got a catastrophic error compiling my program expo (http://www.ba.ic.cnr.it/softwareic/expo/) with ifort 19.1.2.254 20200623 on Ubuntu 18.04.5 LTS.
To quickly reproduce the problem I created a small program in the attached file catastrophic.zip.
To generate the error:
1) unzip the file catastrophic.zip
2) cd castrophic
3) make
and during the compilation of the file spginfo.f90 you will obtain the following error:
spginfo.f90(2292): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
I don't have similar problem in the previous version of compilers. The problem seems platform independent.
Ron_Green
I'll write up a bug report.  thank you for putting together the shorter reproducer.
Ron_Green
The issue is in the "-check all" option.  As you may know, check has a number of arguments in "all".  The specific check causing the crash is:
  -check shape
Just that 1 argument.  So you could do
  -check arg_temp_created,assume,bounds,continguous,format,output_conversion,pointers,stack,udio_iostat,uninit
or any combo therein and this would not get the error.  Just avoid -check shape
I'll get the bug ID here shortly.
Thank you for such a complete reproducer.
Ron_Green
bug ID is CMPLRIL0-33252
Ron_Green
as FYI, the line triggering the crash is 2292.
vet = matmul((spaceg%symop(i)%rot(:,:) - identity_mat(:,:)),tryor) - spaceg%coper(:,nc)
ccorrado
Thanks for the quick response and the suggestion on how to avoid -check shape.
As you probably know, the error disappears by rearranging the line 2292, for example, in this way:
real, dimension(3,3) :: mat
mat = spaceg%symop(i)%rot(:,:) - identity_mat(:,:)
vet = matmul(mat,tryor) - spaceg%coper(:,nc)
Devorah_H_Intel
This was fixed in 2021.4 ifort.
