character function return length specified by dummy arg
David_Mccabe
The following code snippet seems to be working fine in debug and causing access violations in release:
[fortran]
! c_string to character string conversion.
function f_string(cStr,fStr_size) result (fStr)
type(c_string) :: cStr
integer :: fStr_size
character(len=fStr_size) :: fStr
!call c_string_to_character_string(fStr,cStr)
end function f_string
[/fortran]
 Perhaps it is illegal to have the return length specified by dummy arg?
David_Mccabe
The code snippet above work fine, the problem must be introduced elsewhere. This forms part of a test project in where I am trying out type bound procedures for the first time. I have uploaded the project files...
Steven_L_Intel1
David, you have been very naughty. You used BIND(C) to call a STDCALL routine, papering over the error by including the @n name decoration in the external names in the BIND clause. This causes stack corruption. In Intel Fortran, BIND(C) cannot be used to call STDCALL routines - only the default C convention is allowed.
David_Mccabe
Ah! I was unaware this was the case. The code now works fine. Thank you
Steven_L_Intel1
In general, any time you find yourself adding the @n suffix to an external name string to fix up a linking error, that should be a red flag that you're probably doing something wrong.
