class(*) arrays in move_alloc
may_ka
Hi
is there any way to make the example below working??
Program Test
  Class(*), allocatable :: tmp(:,:)
  integer :: i
  integer, allocatable :: b(:,:)
  Allocate(integer::tmp(3,3))
  open(50,file="tmp1.txt",action="read",status="old",iostat=i)
  if(i/=0) Then
    write(*,*) i
  End if
  Do i=1,3
    Select Type(tmp)
    Type Is(Integer)
      read(50,*) tmp(i,:)
    End Select
  End Do
  Do i=1,3
    Select Type(tmp)
    Type Is(Integer)
      write(*,*) tmp(i,:)
    End Select
  end Do
  Select Type(tmp)
  Type Is(Integer)
    call move_alloc(tmp,b)
  End Select
End Program Test
While everything shakes out nicely, the "move_alloc" construct doesn't. I could circumvent it by using a source allocation, but that would double the memory usage until I deallocate tmp. If I haven't got it wrong move_alloc cannot be used because Select Type creates a pointer.
The purpose of the whole exercise is to have a generalized reading routine for rectangular arrays (without writing extra code and using an interface) where I just provide a keyword telling with what data type tmp should be allocated.
Any ideas.
Karl
IanH
No.
Unlimited polymorphic objects in Fortran 2008 are not really suitable for use in generic programming.  They have a role to play in generic storage.
