29423 Discussions
compaq fortran project generates 8284 error message
Brian_Murphy
New Contributor II
I have a LIB project I've been using for years with Compaq fortran.  When I compile it with Intel Fortran I get many error 8284's because scalers are being passed into array arguments in subroutine calls.
Is there a compiler option in Intel Fortran to allow this?
Brian_Murphy
New Contributor II
I think my problem was not doing "extract Compaq visual fortran project items" after project conversion.  So I also tried to create an IVF project from scratch.
I will try the "extract" thing tomorrow.
GVautier
New Contributor III
Hello
This behaviour is no more allowed.
For "static" intent(in) arguments, I think you can use the following syntax :
call subroutine([scalar])
or
call subroutine((/scalar/))
to replace all
call subroutine(scalar)
This was in fact never allowed, but CVF didn't detect the error when you didn't have an explicit interface. Intel Fortran's generated interface checking can detect this error.
Brian_Murphy
New Contributor II
When I did the "extract" thing, the LIB would build without any errors.  By the way, this library is called umfpack which has been around a long time.  I'll bet you've heard of it.  Nowadays umfpack no longer comes exclusively in fortran, but is C with fortran wrappers.  The version I'm working with is 100% fortran.
My next issue has to do with linking things together in a VS solution.  I will start another thread for this.
Brian_Murphy
New Contributor II
I'm still getting similar 8284 errors in other parts of my project.  Can anyone tell me what the "extract" step done as part of the conversion from Compaq did to get rid of the error?  It seems it ought to be a compiler switch somewhere.
It's not what the Extract option did, it's what it didn't do. New projects get the property Fortran > Diagnostics > Check Routine Interfaces set to Yes. Extracted projects do not. If you want to cover up the coding error, set that property to No.
