compile error 8032 on IFWIN FindWindow call
Matthew_Nicoll
I am getting the following compile error:
B:\ios\FWinLib\ivf>ifort /c  /Qsave /nogen-interfaces /align:dcommons  ..\src\fi
nd_window.f90
Intel(R) Visual Fortran Compiler for applications running on IA-32, Version 16.0
.2.180 Build 20160204
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
ifort: NOTE: The evaluation period for this product ends on 18-may-2016 UTC.
..\src\find_window.f90(21): error #8032: Generic procedure reference has two or
more specific procedure with the same type/rank/keyword signature.   [FINDWINDOW
      ihandle = FindWindow(NULL,TITLE(1:L)//CHAR(0))
compilation aborted for ..\src\find_window.f90 (code 1)
On the following Fortran code:
      INTEGER FUNCTION Find_Window(Title)
      USE DFWIN
      CHARACTER(*), INTENT(IN)  ::  Title       ! NOT null terminated
      INTEGER   L,ihandle     ! window handle
      L = LEN_TRIM(TITLE)
      IF (ihandle == NULL) ihandle = 0    ! in case it is different
      Find_Window = ihandle
      RETURN
      END
This compiles fine in CVF 6.6.
In the following topic:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/303421
Steve Lionel (Intel)  Fri, 02/01/2008 - 07:41 wrote:
 "Unfortunately, there is an error in the declaration in the module that makes the generic reference ambiguous. I'll have that fixed in a future release. "
Did that ever get fixed ?!
Should I call FindWindow_G1 instead ?
Is there a simple fix I can make in file user32.f90 (which contains the FindWindow interface declarations)?
Steven_L_Intel1
Whoops! Looks as if that didn't get fixed - sorry!
The fix in user32.f90 is to change:
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpClassName
to:
!DEC$ ATTRIBUTES REFERENCE :: lpClassName
In the declaration of FindWindow_G1. You could also call FindWindow_G1 if you wanted to.
If you change USER32.f90 I suggest copying it to your project and editing it there.
I will make sure this gets fixed for sure!
Matthew_Nicoll
Thanks Steve.  That change in user32.f90 fixed it.
Steven_L_Intel1
This time for sure - escalated as issue DPD200410776.
Steven_L_Intel1
Fixed for 17.0 product.
