29274 Discussions
compiling differences b/w 6.6B & 6.6A
rush19762003
Hi
I've a problem with the code that it compiles and executes on using CVF 6.6A but when I try to compile the same program using CVF 6.6B, i get linker errors. The main error is
errorLNK2001: unresolved external symbol _for_read_dir_i8
errorLNK2001: unresolved external symbol _for_write_dir_i8
1. I wanted to know if this is due to the difference in libraries or compatability b/w the 2 compilers 6.6A & 6.6B?
2. Also please tell me if there are scenarios where programs that compile with CVF 6.6A dont compile with CVF 6.6B?
Hope someone can help me.
Tom Sawyer
Steven_L_Intel1
What is happening is that we made a change to the compiler in 6.6A to enable support of INTEGER*8 record numbers for direct access. In order to link, you need to have the corresponding 6.6A or later run-time library, which added a set of new routines.
I would say that your "6.6B" installation has a mismatch between the compiler and run-time library, as normally this error should not occur. Perhaps you have an old set of libraries in a separate directory that you're linking to?
Steve
