29285 Discussions
compiling errors...I don't know why it occurs about multiple definition between main.o and for_main.o
gtg330c
This is my problem below, if I have compiled my code by ifort, some errors has occurred. I don't know why for_main.o in /opt/intel/fce/9.0/lib/ make this kind of problems... However, main.f90 is made by me.
Could you let me know how to get a solution for my problem? Thanks.
[mycat@mycom dr]$ifort -O3 -tpp7 -Vaxlib -ip -o sm precision.o global.o global_param.o global_app.o main.o init.o
main.o(.text+0x0): In function `main':
: multiple definition of `main'
/opt/intel/fce/9.0/lib/for_main.o(.text+0x0): first defined here
ld: Warning: size of symbol `main' changed from 70 in /opt/intel/fce/9.0/lib/for_main.o to 4052 in main.o
ld: warning: i386 architecture of input file `precision.o' is incompatible with i386:x86-64 output
ld: warning: i386 architecture of input file `global.o' is incompatible with i386:x86-64 output
ld: warning: i386 architecture of input file `global_param.o' is incompatible with i386:x86-64 output
ld: warning: i386 architecture of input file `global_app.o' is incompatible with i386:x86-64 output
ld: warning: i386 architecture of input file `main.o' is incompatible with i386:x86-64 output
ld: warning: i386 architecture of input file `init.o' is incompatible with i386:x86-64 output
/opt/intel/fce/9.0/lib/for_main.o(.text+0x2e): In function `main':
: undefined reference to `MAIN__'
main.o(.text+0x17): In function `main':
: undefined reference to `f90_init'
main.o(.text+0x62): In function `main':
: undefined reference to `f_iof'
main.o(.text+0x82): In function `main':
main.o(.text+0xe2): In function `main':
: undefined reference to `f_iod'
main.o(.text+0xf8): In function `main':
............................ The same problems happens below this line....
Ron_Green
Could you show me your main.f program? Do you have something like:
program main
end program main
If you
nm /opt/intel/fce/9.0/lib/for_main.o
You'll see that 'main' is defined in for_main.o ( "T main ). It is an entry point in the startup routines that wrap and launch your user PROGRAM.
so do this for me:
nm main.o
and look for symbol "main". Is it in main.o as a Target "T main"?
ron
Ron_Green
forgot to add: I would bet $20 that somewhere in your code you have declared a variable named 'main'. Again, 'main' is a special name that you cannot use in your program.
rename 'main' in your code.
ron
Another problem you have is that you used the IA-32 compiler to compile these sources but are then trying to use the x64 (EM64T/Intel 64) ifort to link them.
gtg330c
Thanks for your helps.
As Steve mentions, this problemscan have solved by removing 'main.o' file because this object file of the previousversionmade that and, after then, I have recompiled my code to link.
crkkos
I sourced the ifortvars.sh, iccvars.shto change to the 32 bit compiler for ifort and C respectivly, how do you do it for the linker?
TimP
Quoting - crkkos
The 32-bit compilers automatically invoke the 32-bit linker, assuming the 32-bit g++ and binutils are installed. If you invoke ld directly, it is your responsibility to choose the 32-bit one.
You are using out of date versions of the compilers; an upgrade might be indicated, if only so that the advice seen on this forum may be more relevant.
