- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
My understanding about solutions is that you can have several projects within a given
solution that share common code blocks, such as subroutines, include files, etc.
You should be able to have more than one MAIN program, right ?
so what I have trouble with is: trying to open a NEW PROJECT, but keeping the same solution I had before.
In Visual Studio it always tries to start a NEW solution, something I obviously dont want.
So far I have been unable to get this to work like it's supposed to -
or perhaps I dont understand what a "solution " really is ?
Is that spelled out explicitly anywhere ?
- Marcas:
- Intel® Fortran Compiler
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes
>>projects within a given solution that share common code blocks, such as subroutines, include files, etc
generally yes, but not necessarily. Usually a project will have a collection of subroutines/functions. e.g. a main body project, library/DLL project, general utility functions project, etc...
While you can have multiple Fortran PROGRAM and/or C main projects within a solution, only one of these can be declared as the startup project. A library or DLL cannot be a startup project.
When starting MS VS, "New Project" creates a "New Solution" with that "New Project" contained therein.
For small applications you will have a Solution with 1 Project. As your application code grows, you may find it better to use multiple projects:
One for main/program and higher level procedures (subroutine and functions)
One for modules (think of these as C++ precompiled headers with related code)
One for static or DLL library
Jim Dempsey
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You can add a new project to an existing solution by doing the following:
- In Visual Studio's Solution Explorer, right-click on the Solution name, click Add > New Project
[alternatively, in Visual Studio, with your target Solution open, click on File > Add > New Project] - choose the type of project (e.g. Intel Visual Fortran > Console Application, or > Static Library, etc.)
- enter the name of the new project and click OK
- You will see the new project added to the Solution Explorer
Hope that helps,
Andi
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
A project builds one DLL, LIB or EXE. A solution builds an application from one or more projects. You can have only one main program in a solution.
Simple applications have a solution with one project. You would use additional projects if your application depends on a DLL or LIB, or you have partitioned your application into parts (LIBs) that get shared across several solutions.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Not true. You can have only one Startup Project. This specifies the project, who's executable, is launched from Debug or Start Without Debugging. It is very common to have multiple executable for builds. Examples:
Application + Installation program
Application Scalar variant + Application OpenMP + Application MPI + Installation program
In the above cased, only one of which would be designated as the startup project (and all can have additional projects for static libraries, DLL libraries, test program varients, etc...)
Jim Dempsey
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
