How do I translate a C return to a Fortran return in a a case statement? return CDRF_NOTIFYITEMDRAW; -> FORTRAN CODE???
C Code is as follows:
case WM_NOTIFY:
switch(LOWORD(wParam)) {
case IDC_LIST:
LPNMLISTVIEW pnm = (LPNMLISTVIEW)lParam;
if(pnm->hdr.hwndFrom == hCon &&pnm->hdr.code == NM_CUSTOMDRAW) {
LPNMLVCUSTOMDRAW lplvcd = (LPNMLVCUSTOMDRAW)lParam;
switch(lplvcd->nmcd.dwDrawStage)
case CDDS_PREPAINT :
Fortran translation that I have so far:
TYPE(T_NM_LISTVIEW):: nm; POINTER (pnm,nm)
TYPE(T_NMHDR):: hdr; POINTER (phdr,hdr)
TYPE(T_NMLVCUSTOMDRAW):: lvcd; POINTER(lplvcd,lvcd)
TYPE(T_NMCUSTOMDRAW):: nmcd; POINTER(pnmcd,nmcd)
CASE ( WM_NOTIFY )
phdr = lParam
IF (wParam .EQ. IDC_LIST) THEN
pnm = lParam !not sure why because i never use it?
IF (hdr%hwndFrom.EQ.hCon.AND.hdr%code.EQ.NM_CUSTOMDRAW) THEN
pnmcd = lParam
lplvcd = lParam ! not sure why because i never use it?
IF (nmcd%dwDrawStage .EQ. CDDS_PREPAINT) THEN
RETURN CDRF_NOTIFYITEMDRAW !??? no good ???
END IF
END IF
END IF
Also Can I just do lvcd%nmcd%dwDrawStage and nm%hdr%hwndFrom and not declare phdr = lParam and pnmcd = lParam?
case WM_NOTIFY:
case IDC_LIST:
CASE ( WM_NOTIFY )
phdr = lParam
pnmcd = lParam
END IF
END IF
END IF
Never mind I answered my own question.
MainWndProc = CDRF_NOTIFYITEMDRAW
and
lvcd%nmcd%dwDrawStage .EQ. CDDS_PREPAINT works just fine.
and
