!dec$ define works differently in debug and release
LeonardB
The enclosed sample code works differently when compiling for Debug and Release.
!dec$ define X first in the source code file is walid for the rest of the file when the setting is Release.
When compiling for Debug is X defined only in first routine in the file
jimdempseyatthecove
Interesting. Out of curiosity, turn off all IPO (both compiler and linker) and see what happens.
Jim Dempsey
Lorri_M_Intel
Isn't that interesting ... it's the -warn:interfaces switch.
You can work around this by expliciitly adding -DX on the command line.
I've reported this internally as DPD200245869.
            --Lorri
