decompliling static libraries
Cameron_Crum
I have a problem in that I have have some static libraries that were written several years ago and compiled on 32 bit machines. The person who wrote these for me is now dead and I can't get the orginal source for the libs. I'd like to recompile these into 64 bit. Is there a way to decompile and then recompile into 64 bit?
Martyn_C_Intel
Not to my knowledge. However, you can still build and run 32 bit applications on 64 bit systems. You just can't mix 32 bit and 64 bit objects.
jimdempseyatthecove
You are using FORTRAN
Fortran has available OpenMPI.
You could use OpenMPI and split your FORTRAN program into two processes. One process as 64-bit, the other process as 32-bit. And where the 32-bit contains the code that calls the 32-bit static libraries.
This might be easire to implement than to try to reverse assemble a 32-bit library and also easier (for an inexperienced programmer) than trying to impliment your own messaging system using a memory mapped file.
I consider you investigate OpenMPI.
Jim Dempsey
