Dear Steve, dear all,
I would like to define an apriori unspecified number of allocatable arrays having the same number of dimensions but different size and using all of them more than once in an iterative cycle. The number N of arrays depends on the problem at hand. So it can be specified as an input data or in a parameter declaration. The solutions I conceived seem to be quite unelegant and unefficient from several view points.
1. My first problem is how to allocate the N arrays. I could:
define a large number M > N of alloactable arrays and allocate only N arrays:
Allocatable a1( : , : , : ,), a2( : , : , : ,),, aN( : , : , : ,), , aM( : , : , : ,)
Read dimensions of a1,.,aN
Allocate a1( : , : , : ,), a2( : , : , : ,),, aN( : , : , : ,)
or
Allocate (a(1:N, min_dim_1 : max_dim_1, min_dim_ 2 : max_dim_2, ) )
but this last solution is impractical since could lead to large unused memory allocation for arrays of different number of components in each dimension.
2. My second problem is how to call the N arrays in the iterative cycle in the case of multiple arrays allocation (a1, ..,aN)
do iter = 1, 1000
do k = 1,N
allocate( a( : , : , : ,)) !use same dimensions of ak
select case (k)
case(1);a=a1
case(2);a=a2
case(M);a=aM
end select
!use a
deallocate(a)
enddo
do k = 1,N
as above
enddo
enddo
I could define a single array with an additional dimension ranging from 1 to N, but I should allocate (a(1 : N, min_dim_1 : max_dim_1, min_dim_2 : max_dim_2, ) which is also impractical since could lead to large memory allocation for arrays of different number of components in each dimension.
3. I could create automatically an include file with N declarations and recompile each timeb (but should be forced to recompile a thing that I would avoid)
I hope someone could help me
Thanks in advance
Derived types are your friend. Something like this:
type array_type
real, allocatable :: a(:)
end type array_type
type(array_type), allocatable :: arrays(:)
! Allocate N arrays
allocate (arrays(n))
! Allocate each of the arrays to a different length
do i=1,size(array)
allocate (arrays(i)%a(i*2))
end do
This requires a Fortran 2003 feature which most F95+ compilers support.
Hi!
Is it something like this you are after:
PROGRAM
exampleIMPLICIT NONE
TYPE alloc_type REAL, ALLOCATABLE, DIMENSION(:,:,:) :: a END TYPE alloc_type TYPE (alloc_type), ALLOCATABLE, DIMENSION(:) :: arr INTEGER :: i, iter ALLOCATE (arr(1:2)) ALLOCATE (arr(1)%a(2,3,4)) ALLOCATE (arr(2)%a(3,4,5)) DO iter=1, 1000 DO i=1, SIZE(arr) CALL use_arr (arr(i)%a) END DO IF (iter>10) THEN EXIT ! ----------------> ENDIF END DOCONTAINS
SUBROUTINE use_arr (a) REAL, DIMENSION(:,:,:), INTENT(IN) :: a WRITE (*, *) SHAPE(a) END SUBROUTINE use_arrEND
PROGRAM exampleI have thus made a type, "alloc_type"that consists of an allocatable array and then declared an allocatable array of that type, "arr". Allocation, as you can see, occurs in two steps. First on the "alloc_type" array "arr" and then on its component, "a", for each array element of "arr".
Best wishes
Lars M
The following is what Lars wrote, but it also illustrates the use of pointer types as well.
I did not illustrate all the advantages of using pointers, I will leave that discovery up to you. One advantage is it makes things easire if you desire to have the array of arrays grow/shrink during runtime.
program AllocatableArrays implicit none interface integer function iSomeNumber() end function iSomeNumber end interface interface subroutine foo(A) implicit none real :: A(:,:,:,:) end subroutine foo end interface! Variables! -------------- method 1 -----------! Body of AllocatableArraystype YourArrayTemplate real, allocatable :: A(:,:,:,:)end type YourArrayTemplate! Array Of Arraystype(YourArrayTemplate), allocatable :: ArrayOfArrays(:)! --------------- end method 1 ---------------! --------------- method 2 ----------! Or use pointer to Array Of Arraystype YourArrayTemplateViaPointer real, pointer :: A(:,:,:,:)end type YourArrayTemplateViaPointertype(YourArrayTemplate), pointer :: ArrayOfArraysViaPointer(:)! --------------- end method 2 ----------integer :: NumberOfArrays< P>integer :: Dim1, Dim2, Dim3, Dim4integer :: i! Obtain number of arrays (read from file/console redirected)
NumberOfArrays = iSomeNumber()
! Allocate ArrayOfArrays
allocate(ArrayOfArrays(NumberOfArrays))do i=1,NumberOfArrays ! read dimsDim1 = iSomeNumber()
Dim2 = iSomeNumber()
Dim3 = iSomeNumber()
Dim4 = iSomeNumber()
! allocate allocate(ArrayOfArrays(i).A(Dim1,Dim2,Dim3,Dim4)) ! populate ! ...end do! Obtain number of arrays (read from file/console redirected)
! Allocate ArrayOfArraysViaPointer
allocate(ArrayOfArraysViaPointer(NumberOfArrays))do i=1,NumberOfArrays ! read dimsDim1 = iSomeNumber()
! allocate allocate(ArrayOfArraysViaPointer(i).A(Dim1,Dim2,Dim3,Dim4)) ! populate ! ...end do! sample allocatable
do i=1,size(ArrayOfArrays) call foo(ArrayOfArrays(i).A)end do! sample via pointers (same syntax)
do i=1,size(ArrayOfArraysViaPointer)
call foo(ArrayOfArraysViaPointer(i).A)
end do
write(*,*) "Done"< B>end program AllocatableArrays
implicit none
real :: aRandomNumberaRandomNumber = 0.0
do while(aRandomNumber .lt. 2.) call random_number(aRandomNumber)aRandomNumber = aRandomNumber * 6.
end doiSomeNumber = aRandomNumber
end function iSomeNumbersubroutine foo(A)
implicit none
real :: A(:,:,:,:) integer :: Dims(4)Dims =
shape(A) write(*,*) Dimsend subroutine foo
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
