29389 Discussions
define and use an apriori unknown number of allocatable arrays
bassano
Dear Steve, dear all,
I would like to define an apriori unspecified number of allocatable arrays having the same number of dimensions but different size and using all of them more than once in an iterative cycle. The number N of arrays depends on the problem at hand. So it can be specified as an input data or in a parameter declaration. The solutions I conceived seem to be quite unelegant and unefficient from several view points.
1. My first problem is how to allocate the N arrays. I could:
define a large number M > N of alloactable arrays and allocate only N arrays:
Allocatable a1( : , : , : ,), a2( : , : , : ,),, aN( : , : , : ,), , aM( : , : , : ,)
Read dimensions of a1,.,aN
Allocate a1( : , : , : ,), a2( : , : , : ,),, aN( : , : , : ,)
or
Allocate (a(1:N, min_dim_1 : max_dim_1, min_dim_ 2 : max_dim_2, ) )
but this last solution is impractical since could lead to large unused memory allocation for arrays of different number of components in each dimension.
2. My second problem is how to call the N arrays in the iterative cycle in the case of multiple arrays allocation (a1, ..,aN)
do iter = 1, 1000
do k = 1,N
allocate( a( : , : , : ,)) !use same dimensions of ak
select case (k)
case(1);a=a1
case(2);a=a2
case(M);a=aM
end select
!use a
deallocate(a)
enddo
do k = 1,N
as above
enddo
enddo
I could define a single array with an additional dimension ranging from 1 to N, but I should allocate (a(1 : N, min_dim_1 : max_dim_1, min_dim_2 : max_dim_2, ) which is also impractical since could lead to large memory allocation for arrays of different number of components in each dimension.
3. I could create automatically an include file with N declarations and recompile each timeb (but should be forced to recompile a thing that I would avoid)
I hope someone could help me
Thanks in advance
Derived types are your friend. Something like this:
type array_type
real, allocatable :: a(:)
end type array_type
type(array_type), allocatable :: arrays(:)
! Allocate N arrays
allocate (arrays(n))
! Allocate each of the arrays to a different length
do i=1,size(array)
allocate (arrays(i)%a(i*2))
end do
This requires a Fortran 2003 feature which most F95+ compilers support.
lars_mossberg
Hi!
Is it something like this you are after:
PROGRAM
example
IMPLICIT NONE
TYPE alloc_type
REAL, ALLOCATABLE, DIMENSION(:,:,:) :: a
END TYPE alloc_type
TYPE (alloc_type), ALLOCATABLE, DIMENSION(:) :: arr
INTEGER :: i, iter
ALLOCATE (arr(1:2))
ALLOCATE (arr(1)%a(2,3,4))
ALLOCATE (arr(2)%a(3,4,5))
DO iter=1, 1000
DO i=1, SIZE(arr)
CALL use_arr (arr(i)%a)
END DO
IF (iter>10) THEN
EXIT ! ---------------->
ENDIF
END DO
CONTAINS
SUBROUTINE use_arr (a)
REAL, DIMENSION(:,:,:), INTENT(IN) :: a
WRITE (*, *) SHAPE(a)
END SUBROUTINE use_arr
END
PROGRAM example
I have thus made a type, "alloc_type"that consists of an allocatable array and then declared an allocatable array of that type, "arr". Allocation, as you can see, occurs in two steps. First on the "alloc_type" array "arr" and then on its component, "a", for each array element of "arr".
Best wishes
Lars M
jimdempseyatthecove
The following is what Lars wrote, but it also illustrates the use of pointer types as well.
I did not illustrate all the advantages of using pointers, I will leave that discovery up to you. One advantage is it makes things easire if you desire to have the array of arrays grow/shrink during runtime.
program AllocatableArrays
implicit none
interface
integer function iSomeNumber()
end function iSomeNumber
end interface
interface
subroutine foo(A)
implicit none
real :: A(:,:,:,:)
end subroutine foo
end interface
! Variables
! -------------- method 1 -----------
! Body of AllocatableArrays
type YourArrayTemplate
real, allocatable :: A(:,:,:,:)
end type YourArrayTemplate
! Array Of Arrays
type(YourArrayTemplate), allocatable :: ArrayOfArrays(:)
! --------------- end method 1 ---------------
! --------------- method 2 ----------
! Or use pointer to Array Of Arrays
type YourArrayTemplateViaPointer
real, pointer :: A(:,:,:,:)
end type YourArrayTemplateViaPointer
type(YourArrayTemplate), pointer :: ArrayOfArraysViaPointer(:)
! --------------- end method 2 ----------
integer :: NumberOfArrays
< P>
integer :: Dim1, Dim2, Dim3, Dim4
integer :: i
! Obtain number of arrays (read from file/console redirected)
NumberOfArrays = iSomeNumber()
! Allocate ArrayOfArrays
allocate(ArrayOfArrays(NumberOfArrays))
do i=1,NumberOfArrays
! read dims
Dim1 = iSomeNumber()
Dim2 = iSomeNumber()
Dim3 = iSomeNumber()
Dim4 = iSomeNumber()
! allocate
allocate(ArrayOfArrays(i).A(Dim1,Dim2,Dim3,Dim4))
! populate
end do
! Allocate ArrayOfArraysViaPointer
allocate(ArrayOfArraysViaPointer(NumberOfArrays))
! read dims
! allocate
allocate(ArrayOfArraysViaPointer(i).A(Dim1,Dim2,Dim3,Dim4))
! populate
end do
! sample allocatable
do i=1,size(ArrayOfArrays)
call foo(ArrayOfArrays(i).A)
end do
! sample via pointers (same syntax)
do i=1,size(ArrayOfArraysViaPointer)
call foo(ArrayOfArraysViaPointer(i).A)
end do
write(*,*) "Done"
< B>end program AllocatableArrays
implicit none
real :: aRandomNumber
aRandomNumber = 0.0
do while(aRandomNumber .lt. 2.)
call random_number(aRandomNumber)
aRandomNumber = aRandomNumber * 6.
end do
iSomeNumber = aRandomNumber
subroutine foo(A)
implicit none
real :: A(:,:,:,:)
integer :: Dims(4)
Dims =
shape(A)
write(*,*) Dims
end subroutine foo
