29640 Discussions
derived types, keyword initialization, allocatable characters...
John4
Valued Contributor I
I'm not sure if the code below is valid, or if it's a compiler bug (or if I've finally gone insane), but it seems that combining derived types keyword initialization with allocatable characters sets a fixed length for all the variables initialized in such way ---i.e., the length of "first" and "second" for the t variable, is always four.
implicit none
type :: myType
character(:), allocatable :: first
character(:), allocatable :: second
end type
type(myType) :: y, t(3)
integer :: i
y = myType(first = 'this', second = 'that')
t = [myType(first = 'those', second = 'not'), &
myType(first = 'a little longer', second = 'the same'), &
myType(first = 'still much longer', second = 'the same')]
do i = 1, SIZE(t)
print '("t(", I0, ")%first = ", A)' , i, t(i)%first
print '("t(", I0, ")%second = ", A)' , i, t(i)%second
enddo
end
Fixed in 11.1 Update 6.
Not always 4 - always the length in the assignment to y. Compiler bug. It sounds vaguely familiar - I'll check further when I get in on Monday.
I knew it sounded familiar - but the previous one was a bit different in that it involved array constructors and was non-standard code. Yours is standard-conforming and should work. It would appear that whatever length is used in the first appearance of the structure constructor is reused for all subsequent appearances!
Reported as issue DPD200148508.
This has been fixed in our sources - the fix should appear in 11.1 Update 5, scheduled for mid-February.
John4
Maybe I'm doing something wrong here, but... With 11.1 Update 5, and the code I provided above, text is still truncated.
My apologies - I had been told that the fix would be in Update 5, but indeed it is not. I will check with the developer on this.
This was apparently my misunderstanding. The fix has been checked in for Update 6.
