I am considering buying a new PC system with Dual Core processor. Does the Dual Core processor support Intel EM64T to develop 64-bit applications with Intel Fortran?
Wen
The Core™ 2 Duo processors support EM64T (now renamed "Intel 64" - go figure.) This would be the ones that will be officially launched tomorrow, code named Conroe. The earlier "Core™ Duo" (without the 2) processors, used in laptops and the current Apple Macs, do not support EM64T.
Yes, you can use the Intel Fortran compiler to develop 64-bit applications for these new processors. The 64-bit compiler, still referred to as "Intel EM64T", is a separate install option and requires that you have the Microsoft Platform SDK or Visual Studio 2005 installed.
Thank you. Steve.
I am having a system with 3.80 GHz Xeon processor, XP Professional, and Visual Studio 2005. Could I install IVF 9.1 with the 64-bit option? Dont I need XP Professional x64 installed?
Wen
You can certainly install IVF 9.1 and the EM64T compiler. You can build EM64T applications on a 32-bit Windows system but can't run them there. If you want to develop and run then you will need one of the x64 variants of Windows running on the box.
Topic Options
