29653 Discussions
dual solution, bug in the code or compiler error?
S__MPay
I just noticed each time I run my model, initial steps are exactly same until after a specific step I get slightly different results.
First I was almost sure that I made a mistake in my code but when I visualize the results I see that each case makes sense:
Solution 1: a crack starts from A and propagates
Solution 2: a crack starts from B and propagates
I now suspect dual solution; but I don't understand how it is possible that one code can generate different results each time I run it.
I am not using any randomization and the problem is exactly same.
I would appreciate if you could help me to understand 'what am I facing'?
Johannes_Rieke
New Contributor III
Hi, the MKL documentation covers the topic 'reproducible results' also, if I remember correctly. Further I found these documents:
https://software.intel.com/en-us/articles/introduction-to-the-conditional-numerical-reproducibility-cnr
https://software.intel.com/en-us/mkl-macos-developer-guide-obtaining-numerically-reproducible-results
In my codes I use the following settings and get normally good reproducible results (openmp/no openmp, Od vs. O3):
/fp:source /Qfp-speculation=safe /Qimf-precision:high
Further, to find issues with missing initialization, although I don't think from comparison debug/release that this is an issue for you, you can choose the compiler options:
/Qinit:snan /Qinit:arrays
Johannes_Rieke
New Contributor III
Hi, just a speculation:
Arjen_Markus
Another possibility: are you using OpenMP or other multithreading/multiprocessing constructs? If so, you can simply not be sure that from one calculation to the next things are handled in exactly the same way. As we do not know anything about your program, it is difficult to be more specific.
S__MPay
Dear Johannes,
Thank you very much, your comments are really useful for me, especially the floating point model.
johannes k. wrote:
  • ...Do you get the same results in debug and release mode?
I could verify some difference in debug mode (from step 4 iteration 180):
Run 1
Analysis started..  Total steps: 20                    2018/03/16 15:47:44.2
    Step 1     out of 20       convergence:  0.16E+03  2018/03/16 15:47:50.0
     >iteration 1 convergence:0.1079E+03:0.1079E+03
    Step 4     out of 20       convergence:  0.47E+03  2018/03/16 15:51:59.8
     >iteration 1   convergence:0.2544E+03
     >iteration 180 convergence:0.1995E+02
     >iteration 181 convergence:0.1981E+02
     >iteration 182 convergence:0.1968E+02
     >iteration 183 convergence:0.1955E+02
     >iteration 298 convergence:0.1002E+02
     >iteration 299 convergence:0.1001E+02
     >iteration 300 convergence:0.1001E+02
and in another analysis the numbers become slightly different:
Run 2
    Step 4     out of 20       convergence:  0.47E+03  2018/03/16 16:00:52.8
     >iteration 181 convergence:0.1982E+02
     >iteration 182 convergence:0.1969E+02
     >iteration 183 convergence:0.1956E+02
     >iteration 298 convergence:0.1049E+02
     >iteration 299 convergence:0.1045E+02
     >iteration 300 convergence:0.1042E+02
Also step 4 in which this difference happens takes a very long number of iterations to converge.
S__MPay
Yes, I am using multithreading (the code runs on an Intel 10-core CPU machine).
I also link MKL library using Qmkl:parallel
Still trying to find which part in the code will cause such behavior but no luck so far.
Johannes_Rieke
New Contributor III
S__MPay
This won't apply if I use EXPLICIT NONE, am I correct?
Arjen_Markus
The problem is that with multithreaded calculations things may be done in a different order from one run to the next. Suppose you have three threads and a fourth must sum the results:
Run 1:
Thread 4 gets the results in the order thread 1, thread 2, thread 3: answer = (R1+R2) + R3
Run 2:
Thread 4 gets the results in the order thread 3, thread 1, thread 2: answer = (R3+R1) + R2
As floating-point arithmetic cannot guarantee that the two answer are exactly the same, there is an opportunity for a random variation in the results. If your agorithm is senstive to small variations, this might be the cause.
Steve_Lionel
S. MPay wrote:
You mean IMPLICIT NONE? That has no effect here. The /Qinit options help detect uninitialied values at runtime.
S__MPay
Yes, I can admit that the algorithm is likely to be sensitive to small variation in this case.
S__MPay
Yes, sorry for the mistake (I was thinking of option explicit probably!)
I see, so /Qinit:snan will set uninitialized variables to NAN value I suppose.
I will give those options a try and see.
TimP
My former colleagues cited legitimate cases in crack propagation where 2 solutions are equally valid within the accuracy of floating point arithmetic.  Then, as hinted above, parallel computing could produce this situation where either solution might appear, due to insignificant differences in order of computation.  Also, as hinted above, uninitialized data could trigger one or the other, even if the difference in initial values isn't significant.  There may actually be a physical correspondence even when a correctly modeled experiment is undertaken i.e. very small differences in temperature or orientation might sometimes cause the crack to jump.  Of course, you should assure in practice that you don't have uninitialized data, for example because you may not have control over whether differences are significant.
S__MPay
Dear Tim, Thank you very much, is it possible to have the citation of that research just in case you know.
gib
New Contributor II
I would try running the code with a single processor.
