-dynamic: No such file or directory
Marc_R_1
Whenever I try to compile with ifort (i.e. ifort test.f90)  I get the following error:
I am guessing this is because the terminal is not finding the correct folder with the complier info in it but I don't know how to resolve this issue. Thanks!
You make the compiler available with:
source /opt/intel/bin/ifortvars.sh intel64
(Replace "intel64" with "ia32" if you are building for 32-bit).
Marc_R_1
Hi Steve,
I entered the command into the terminal and tried to compile my test code again and I still get the same response as before:
I double checked that I have a 64bit processor and that the file you linked to in the source directory exists. Could there be something I am missing?
Please show the full output including the command used. Is there an "ifort.cfg" file anywhere on your system and if so, what are its contents?
Please show the output of:
ifort -dryrun test.f90
Marc_R_1
Ok, below are the outputs of both the commands. There is an ifort.cfg file an its only content is the line "# This Configuration file may be used for additional switches"
Thanks!
marcs-mbp:Fortran marc1russell$ ifort  test.f90
marcs-mbp:Fortran marc1russell$ ifort -dryrun test.f90
/opt/intel/composer_xe_2013_sp1.3.166/bin/intel64/fortcom  \
    -D__INTEL_COMPILER=1400 \
    -D__INTEL_COMPILER_UPDATE=3 \
    -D__x86_64 \
    -D__x86_64__ \
    -D_MT \
    -D__INTEL_COMPILER_BUILD_DATE=20140415 \
    -D__PIC__ \
    -D__APPLE__ \
    -D__MACH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -D__tune_pentium4__ \
    -D__SSE2__ \
    -D__SSE3__ \
    -D__SSSE3__ \
    -D__SSE__ \
    -D__MMX__ \
    -mGLOB_pack_sort_init_list \
    -I. \
    -I/opt/intel/composer_xe_2013_sp1.3.166/mkl/include \
    -I/opt/intel/composer_xe_2013_sp1.3.166/compiler/include/intel64 \
    -I/opt/intel/composer_xe_2013_sp1.3.166/compiler/include \
    -I/usr/include \
    -O2 \
    -simd \
    -mP1OPT_version=14.0-intel64 \
    -mGLOB_diag_file=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortiK4NxM.diag \
    -mGLOB_diag_use_message_catalog=FALSE \
    -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
    -mP2OPT_static_promotion \
    -mP1OPT_print_version=FALSE \
    -mCG_use_gas_got_workaround=F \
    -mP2OPT_align_option_used=TRUE \
    -mGLOB_gcc_version=481 \
    -mGLOB_options_string=-dryrun \
    -mGLOB_position_independent_code \
    -mGLOB_preemption_model=1 \
    -mGLOB_no_compact_unwind=TRUE \
    -mGLOB_cxx_limited_range=FALSE \
    -mCG_extend_parms=FALSE \
    -mGLOB_compiler_bin_directory=/opt/intel/composer_xe_2013_sp1.3.166/bin/intel64 \
    -mGLOB_as_output_backup_file_name=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortD24Afras_.s \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mGLOB_em64t \
    -mGLOB_instruction_tuning=0x0 \
    -mGLOB_product_id_code=0x22006d8f \
    -mCG_bnl_movbe=T \
    -mGLOB_extended_instructions=0x80 \
    -mP3OPT_use_mspp_call_convention \
    -mP2OPT_subs_out_of_bound=FALSE \
    -mGLOB_ansi_alias \
    -mPGOPTI_value_profile_use=T \
    -mP2OPT_il0_array_sections=TRUE \
    -mP2OPT_hlo_level=2 \
    -mP2OPT_hlo \
    -mP2OPT_hpo_rtt_control=0 \
    -mIPOPT_args_in_regs=0 \
    -mP2OPT_disam_assume_nonstd_intent_in=FALSE \
    -mGLOB_imf_mapping_library=/opt/intel/composer_xe_2013_sp1.3.166/bin/intel64/libiml_attr.dylib \
    -mIPOPT_obj_output_file_name=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortiK4NxM.o \
    -mIPOPT_whole_archive_fixup_file_name=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortwarchtjoLa6 \
    -mGLOB_long_size_64 \
    -mGLOB_routine_pointer_size_64 \
    -mGLOB_driver_tempfile_name=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/iforttempfile9aAZQ1 \
    -mGLOB_os_target=GLOB_OS_TARGET_MACH \
    -mGLOB_async_unwind_tables=TRUE \
    -mGLOB_obj_output_file=/var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortiK4NxM.o \
    -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
    -mP1OPT_source_file_name=test.f90 \
    -mP2OPT_symtab_type_copy=true \
    test.f90
    -arch \
    x86_64 \
    -weak_reference_mismatches \
    non-weak \
    -macosx_version_min \
    10.9.3 \
    -no_compact_unwind \
    -o \
    a.out \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/for_main.o \
    -L/opt/intel/composer_xe_2013_sp1.3.166/compiler/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.166/mkl/lib \
    -L/usr/lib \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libifport.a \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libifcore.a \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libimf.a \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libsvml.a \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libipgo.a \
    -lSystem \
    /opt/intel/composer_xe_2013_sp1.3.166/compiler/lib/libirc.a \
    -lpthread \
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortxcrun4tMXQE
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortxcrun67nVbt
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortxcrunXW3Pqs
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortxcruniGxjfN
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortgnudirsXINWXZ
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortxcrunpxUXIz
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortclangdashvybBTnJ
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortiK4NxM.o
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortose7fhUI
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/iforttoswULi83
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortD24Afras_.s
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/iforttempfile9aAZQ1
rm /var/folders/vx/d5gj9dbj5n36xrzlgfvxr6500000gn/T/ifortargLZoXqQ
Ah, you're on OS X. Do you have gcc installed? Which Xcode version?
Marc_R_1
Thanks Steve! It works now. I had downloaded Xcode but I guess I needed to run the program for it to actually finish setting itself up.
Glad to hear it.
