error 2 error #6633
ali_p_
Hello all
im a physics student and i am working on a simulation project so my doctor gave me an old fortran script for the simulation which he had written few years ago the problem is when i try to debug it,it shows error #6633: the type of the actual argument differs from the type of the dummy argument.[0]
several times this is one of them  :
call moveto_w(0,0,wxy)
       dummy=setcolor(9)
       ekm=abs(phif(2,2))
       do j=1,ngx
	ekm=amax1(ekm,phif(1,j),phif(2,j),phif(3,j))
       end do
       call moveto_w(500/ngx,phif(1,1)*100*.8/ekm,wxy)
       do j=1,ngx
	   dummy=lineto_w(j*500/ngx,phif(1,j)*100*.8/ekm)
       end do
       call moveto_w(500/ngx,phif(2,1)*100*.8/ekm,wxy)
       do  j=1,ngx
	   dummy=lineto_w(j*500/ngx,phif(2,j)*100*.8/ekm)
       end do
and the declarations of this subroutine goes like this:
subroutine fieldf (ith)
       include 'fgraph.fd'
	common/param/ nsp,lx,ly,dx,dy,dt,nt
	common/cfield/ ngx,ngy ,iw,rho0,g1(34,34),ex(34,34),ey(34,34)
     $,bz(34,34)
	common /xvp/ x(25602),y(25602),vx(25602),vy(25602)
	common/cntrl/it,time,ithlx,ithly,iex,iey,ixvx,iyvy,
     $  ivxvy,ifvx,ifvy
	integer*2 dummy
       record /wxycoord/ wxy
	integer ith,l,ng2,hdx,hdy,ik,jk
	real lx,ly,pi,erun1,erun2,kdx2,sm(34),ksq(34),eset,phif(34,34)
     $,rhof(34,34),sc(34),rhok(34),lxlyi
	data ng2,pi/0,3.128/
ps:im not very familiar with fortran coding and im using vs2012
Arjen_Markus
>> now do i just create a file named "fgraph.fd" with this code in it and add it to the project's directory?
No, need for that. Like I said, the compiler can find it somewhere, possibly in its own installation directory.
This does make it possible to guess what is going on though. The structure "wxycoord" uses double precision reals, so my guess is that all coordinates are expected to be double precision. You will have to change your declarations from "real" to "double precision". And lines like:
to (the "d0" indicates a double precision constant)
call moveto_w(0.0d0,0.0d0,wxy)
call moveto_w(500.0d0/ngx,phif(1,1)*100*.8d0/ekm,wxy)
to force the coordinates to double precision.
ali_p_
i did not change the original fgraph.fd
Arjen_Markus
Can you tell us which libraries are included in the link step? I found the settextposition routine (apparently the actual name is _fq_settextposition) in libifcore.lib, so that library should be included in any case
ali_p_
r u suggesting to change the lines with "settextposition" to "_fq_settextposition"?
FortranFan
ali p. wrote:
it's not in the routine that contain the include fgraph.fd
but i solved it.
now i have 2 linking errors
   desecription        file
Error    1     error LNK2019: unresolved external symbol SETTEXTPOSITION referenced in function MAIN__    EM2DB.obj
Error    2     fatal error LNK1120: 1 unresolved externals        EM2DB.exe
Isn't SETTEXTPOSITION an Intel graphics subroutine: https://software.intel.com/en-us/node/526772.  How're you linking your code?  If your setup and configuration is ok, this procedure should get found from the Intel's core Fortran library.
ali_p_
thanks for responding
i managed to solve the linking problem i think!!
and now when it starts running i get this runtime error forrtl:server 157:PROGRAM EXCEPTION access violation
i keep getting this error
any idea why ??!
em_0.jpg482344
Arjen_Markus
Accessing array elements outside the bounds of the array or incorrect argument lists when you call a subroutine or a function are all ways to make the program crash with this type of errors. There are others as well. The fastest way forward is to run it in the debugger. It may be that the problem is gone when you do that. In that case use the option to print a proper stacktrace, that ought to give you an idea where things are going wrong.
There are other possibilities to hunt down the cause, like inserting write statements at strategic positions, but I would suggest you use the debugger first.
ali_p_
the debugger dosn't show errors or warnings and run through to this point
im also using this file as data file
laser parameters Io,kl,ml,wo,wpe,ld,lat,npr,z,ne
1e9,.16,.25,3.2899,8.602e12,.0001,200,2,13,1.788521
nsp,lx,ly,ngy,ngx,nt,dt,ie,irho,ixy,ifvx,ihis
1,100.,100.,32,32,2000,.08,2,50,50,200,1
p,wp,wc,qm,vx0,vy0,x1,y1,vt,iw
22500,1.,1.,-1.,0.,0.,0.0,0.0,1.0,2
name of the output fiels(electrostatic mode,history)
mod20cc.dat    his20cc.dat    ve20cc.dat
ali_p_
so i did set several breakpoints and i found the statement
that is causing this error
         subroutine accel(ilp,iup,m,q,ke,te,DRE,Einb)
	  common /param/nsp,lx,ly,dx,dy,dt,nt
	  common/cfield/ngx,ngy,iw,rho0,g1(34,34),ex(34,34),ey(34,34)
     $,bz(34,34)
          real m ,q ,ke,ae,tem,ael,exx,exxx,eyy,eyyy,vxvy,lx
     $,ly,dx,dy,dt,ex,ey,dre,sumx,sumy,te,bzz,bzzz,einb,m2
	  integer j1,i1
	  ael=1.
*******  advance velocity one time step
	 dxdt=dx/dt
	 ae=(q/m)*dt/dxdt
	 AE=0.5*ae
	 if(ae.eq.ael) go to 60
	  tem=ae/ael
	 do 1 i=1,ngy+1
	 do 1 j=1,ngx+1
	 ex(i,j)=ex(i,j)*tem
	 ey(i,j)=ey(i,j)*tem
1        continue
	 ael=ae
60       continue
******** select acceleration weighting *******
c         goto 300
        do 3 i=ilp,iup-1
	i1=y(i)
	j1=x(i)
	exx=ex(i1+2,j1+2)*(y(i)-i1)*(x(i)-j1)+ex(i1+2,j1+1)*(y(i)-i1)*
     $    (j1+1-x(i))+ex(i1+1,j1+2)*(i1+1-y(i))*(x(i)-i1)
	 exxx=exx+ex(i1+1,j1+1)*(i1+1-y(i))*(j1+1-x(i))
	 eyy=ey(i1+2,j1+2)*(y(i)-i1)*(x(i)-j1)+ey(i1+2,j1+1)*(y(i)-i1)*
     $    (j1+1-x(i))+ey(i1+1,j1+2)*(i1+1-y(i))*(x(i)-i1)
	 eyyy=eyy+ey(i1+1,j1+1)*(i1+1-y(i))*(j1+1-x(i))
	bzz=bz(i1+2,j1+2)*(y(i)-i1)*(x(i)-j1)+bz(i1+2,j1+1)*(y(i)-i1)*
     $    (j1+1-x(i))+bz(i1+1,j1+2)*(i1+1-y(i))*(x(i)-i1)
	bzzz=bzz+bz(i1+1,j1+1)*(i1+1-y(i))*(j1+1-x(i))
	c=cos(bzzz*dt)
	s=sin(bzzz*dt)
	vy(i)=vy(i)+eyyy
	 vx(i)=vx(i)+exxx
	 vyy=-vx(i)*s+vy(i)*c
	 vxx=vx(i)*c+vy(i)*s
	 vy(i)=vyy+eyyy
3        vx(i)=vxx+exxx
	 vxvy=0.
c         am=0.5*wp2m*(lx/ngx)**2
         Einb=Einb*.5/(iup-1)*1/(dxdt*dxdt)
         m2=m/2
it's this last one (Einb=Einb*.5/(iup-1)*1/(dxdt*dxdt)
                            m2=m/2)
i don't know what's wrong with it as i mentioned i don't use fortran
FortranFan
ali p. wrote:
.. as i mentioned i don't use fortran
I notice you keep mentioning you don't use Fortran.  And you've also mentioned you're a student of Physics (graduate school?) and that your "doctor" (thesis advisor?) has given you some code to run.  Since you're a student, you can help yourself greatly if you take a structured approach to learning Fortran using readily available online resources (even YouTube has a lot to offer on Fortran) including some links shown below.  If you're studying Physics, Fortran skills can be something you will find valuable for the rest of your Physics/science/technical career, plus if you are able to study something like Physics at some advanced level, picking up Fortran such as from the PDF link below should be a "piece of cake", just a few days' worth of effort following which you can resolve by yourself almost all the problems you're bringing up in the long thread in this topic.
http://www.egr.unlv.edu/~ed/fortran (find a downloadable PDF file at the site)
and
http://fortranwiki.org/fortran/show/Tutorials
Now if you're interested in advancing yourself further in Fortran, you can also try the recommendations by Dr Fortran as suggested here: https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-...
mecej4
There are two calls to subroutine ACCEL. In the second of these, in line 577 of the source code that you gave in #26, the last argument is the constant 0.0. The statement on line 629 attempts to update the value of this argument; i.e., an attempt is made to write a new value into a read-only memory location. You need to ask your doctor what to do, but a simple fix that may suffice is to replace "0.0" in line 577 by "(0.0)".
ali_p_
and
actually im undergraduate and i am familier with c++ and i dont have that much programing application in my study and it wont be that easy for me to learn fortran cuz its look like a very complicated lang with so much compiling issues I dont get that with c++ although my work is not that sophisticated and another thing english is not my first language so it would be rather hard for me to start to learn about new coding style and will take some time to do it..thanks for recomending these sources though We actually have (modern fortran explained ) book in my uni library l will take a look at it
ali_p_
Thanks i will try that..hope it works
Arjen_Markus
In my experience C++ is far more complicated than Fortran. The problem you are facing is that you are dealing with old program code that does not take advantage of the facilities that have been defined some 30 years ago with the publication of the newer standard Fortran 90 and are unfamiliar with the syntax. I understand this is frustrating, but that is hardly the fault of the language itself. Just my two cents ;)
ali_p_
arjenmarkus wrote:
[/quote
Thanks very much u look like a fortran genius,and yeah i understand that fortran had few versions and that what causing the trouble..but does
That mean if i compile this on old fortran 77 compiler only on old system it might work without problems ?? And if so which system and compiler i can use for that.
mecej4
ali p. wrote:
I understand that fortran had few versions and that what causing the trouble..but does that mean if I compile this on old fortran 77 compiler only on old system it might work without problems ?
There is no need to launch grand discourses on C++ versus Fortran, or to resurrect old computer boxes.
The Fortran program given to you has a bug and I showed you a simple fix for it. Make that correction and run the program. If the output graphs look right, the story ends there. If not, you can come back with your objections.
