29656 Discussions
error #5082: Syntax error, found END-OF-STATEMENT when expecting one of ...
Jervie
I'm trying to compile my Fortran code using OneAPI mpiifort, and I got the following error:
mpiifort -O2 -ip -w -ftz -align all -fno-alias -no-heap-arrays -c -i4 -r8 -convert big_endian -assume byterecl -mcmodel=medium -extend_source -fp-model strict -free -I. -I/usr/local/include -I/usr/include -I/opt/intel/oneapi/mpi/2021.2.0/include endrun.f90
areaMod.f90(313): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <LABEL> <IDENTIFIER> TYPE MODULE ELEMENTAL IMPURE NON_RECURSIVE PURE RECURSIVE ...
do jo = 1, nlat_o
mpiifort -O2 -ip -w -ftz -align all -fno-alias -no-heap-arrays -c -i4 -r8 -convert big_endian -assume byterecl -mcmodel=medium -extend_source -fp-model strict -free -I. -I/usr/local/include -I/usr/include -I/opt/intel/oneapi/mpi/2021.2.0/include mkrank.f90
areaMod.f90(273): error #6218: This statement is positioned incorrectly and/or has syntax errors.
subroutine areaave (nlat_i , nlon_i , numlon_i, fld_i , &
areaMod.f90(346): error #6702: END statement confusion.
end subroutine areaave
compilation aborted for areaMod.f90 (code 1)
gmake: *** [/home/bianqy/BCC_ESM_OneAPI//models/bld/Makefile:138: areaMod.o] Error 1
gmake: *** Waiting for unfinished jobs....
exit 2
However, the code could be compiled using Intel 2018 (2018.1.163) mpiifort. But for some reason, I have to use OneAPI to compile my code. Any suggestions are aprreciated!
I attached the code of areaMod.f90 in case.
Labels (2)
Arjen_Markus
When I compiled it, I noticed an error message about "!dir$ inlinenever areaave. The complaint was about an identifier "never", so I guess the keyword "inlinenever" is unknown. Removing that line made the error about subroutine areaave go away.
Jervie
Hi, thank you very much for your reply. Following you advice, I commented the line "!dir$ inlinenever areaave", and the error go away.  I also tried Andrew's advice, by changing "!dir$ inlinenever areaave" to "!DIR$ ATTRIBUTES NOINLINE :: areaave", the error also go away. It turned out to be a format issue. The ATTRIBUTES directive option NOINLINE should be written as "!DIR$ ATTRIBUTES NOINLINE :: procedure" for OneAPI fortran compiler.
andrew_4619
Jervie
Thank you very much! It solves my issue.
mecej4
Check the INLINE directives in your source files. They appear to be be meant for the Cray Fortran compiler, and not all are supported in Intel Fortran.
Jervie
Hi, yes! By changing "!dir$ inlinenever areaave" to "!DIR$ ATTRIBUTES NOINLINE :: areaave", the error go away. It turned out to be a format issue. The ATTRIBUTES directive option NOINLINE should be written as "!DIR$ ATTRIBUTES NOINLINE :: procedure" for OneAPI fortran compiler.
