I am working on a pile of code originally developed under Lahey/Fujitsu.There are several utility libraries I need to rebuild to link the project. Here are the errors i got while compiling one of the libraries (Util):
error #7589: Not a valid value for the char-expr in this connect-spec. ['TRANSPARENT']
error #5082: Syntax error, found ERROR-OF-STATEMENT when expecting one of :(%[:.==>
error #6236: A specification statement cannot apprear in the executable section.
The line of code is
IF (INIT .EQ. 0) THEN
C initialize output screen
OPEN(UNIT=6,FILE='CON',ACCESS='TRANSPARENT',BLOCKSIZE=4096)
INIT= 1
CFORE= FORE
CBACK= BACK
CSET = 1
I googled the error message. It seemed the problem is caused by the imcompatiblity in thisACCESS='TRANSPARENT'between LF and other Fortran compiler like Intel fortran. I tried a couple of ways, but was still unable to fix the problem.
Please help! Very appreciate it.
Our compiler does not have a "TRANSPARENT" choice for ACCESS. You should picke from one of our access methods that will work with your file. I am not sure what "TRANSPARENT" means for Lahey.
Here are the ones Intel Fortran supports:
Wendy
Attaching or including files in a post
OPEN: ACCESS Specifier
The ACCESS specifier indicates the access method for the connection of the file. It takes the following form:
ACCESS = acc
acc | Is a scalar default character expression that evaluates to one of the following values:
The default is 'SEQUENTIAL'.
There are limitations on record access by file organization and record type.
Parent topic: OPEN Statement Specifiers- Mark as New
Use the available nonstandard file attribute FORM='BINARY', or use the newer STREAM access method.
Hi wendy,
Thanks a lot for your reply!
I changed the access to 'STREAM' but there are still errors:
error #5082: Syntax error, found END-OF-STATEMENT when execting one of :(%[:.==>
Regarding 'TRANSPARENT' in Lahey, this is what i found
"Converting unformatted files with LF90 or LF95 usually involves opening the file using the specifier ACCESS="TRANSPARENT" (a nonstandard Lahey extension), which allows the file to be read a byte at a time with no assumptions about headers or record delimiters. This allows one to have the same degree of control as when handling files in the C language. For an example of this technique, see the file SEQUNF.F90, provided in the LF90 and LF95 installations."
What do you think would be the problem?
I changed both 'TRANSPARENT' (in different subroutines) to 'STREAM', but still didn't work...
INIT= 1
CFORE= FORE
CBACK= BACK
CSET = 1
C initialize keyboard
OPEN(UNIT=5,FILE='CON',ACCESS='TRANSPARENT',BLOCKSIZE=256)
C allow control-break
OPTION BREAK
INIT= 1
END IF
Errors indicated in the line after the 2nd OPEN:
error #5082: Syntax error, found END-OF-STATEMENT when expecting one of :(%[;.==>
Did i mistaken anything here?
Well, yes, if you want to use a Fortran compiler, you should be removing the non-Fortran directives from the source.
Can you please tell me what are not fortran directives here?
I know it sounds stupid, but I never used Lahey either.
Thanks for the help.
SeemsOPTION BREAK is the one. Removed it ! OPTION BREAK.
It worked!
Thanks a lot!!
Topic Options
