error in running fortran in abaqus6.8
fqinfortran
Hi, experts.
I've installed IVFortran v9.1 and microsoft visual c++2005 and try to integrate with Abaqus v6.8-1.
I'm trying to run the command under abaqus jobs directory using
c:\\abaqus jobs>abaqus job=plate-vusdfld user=xx.VUSDFLD interactive
This command is to run the job with user subroutine.
But I got the error as follows:
"Begin Compiling Single Precision Abaqus/Explicit User Subroutines
ifort: error: could not find 'cl'
End Compiling Single Precision Abaqus/Explicit User Subroutines
Begin Linking Single Precision Abaqus/Explicit User Subroutines
ValueError: LINK.exe not found in PATH.
So what should I do next to fix it?
Could anyone help me out?
BTW, the operating system is windows xp 64 digit.
Steven_L_Intel1
Ok, that's easy then. Drag a copy of the Intel Visual Fortran Build Environment for EM64T applications shortcut to your desk (be sure not to do a "Move".) Right click on it and select Properties. Change the Start In to be C:\Abaqusjobs Change the name of the shortcut to be Abaqus.
Steven_L_Intel1
Well, that is an old version of Fortran, but...
The "could not find cl" means that it was not able to locate Microsoft Visual C++ so that it knows which version to use. Have you established the Fortran build environment using the ifortvars.bat script? That it could also not find LINK implies to me that you have not done this.
fqinfortran
Hi, Steve.
Thank you for your reply.
I just installed microsoft visual c++ 2005 into default directory.
Then I installed Intel visual fortran v9.1 also using the default directory.
Could you tell me hwo to establish the Fortran build environment using the ifortvars.bat script.
TimP
The easy way is to use the shortcut on the Start menu to open the ifort command prompt window. The shortcut sets up the ifort and cl environments for you. If you wish to do it in a window which you opened yourself, you can use the .bat file as the shortcut invokes it.
fqinfortran
Hi TimP,
Could you show me how to do that in an easy way?
I'm new to Fortran use with micro visual studio. The following pic is my screenshot.
I don't know how to do that.
I'm searching this information on the web but cannot find the case like mine.
fqinfortran
I found the following source on the web.
"Intel Visual Fortran Compiler 9.1 for Windows* Release Notes
If you want to reference an existing installed Platform SDK from within Visual Studio 2005, you can do so in one of two ways:
  1. Open the appropriate build environment command window (Start.. All Programs.. Intel Software Development Tools.. Intel Fortran Compiler 9.1..Build Environment for ) and issue the commands:
    "C:\Program Files\Microsoft Platform SDK\SetEnv.bat"
    "C:\Program Files\Microsoft Visual Studio 8\Common7\IDE\devenv" /useenv
    The first command invokes the environment setup procedure for the Microsoft Platform SDK you are using, and the second starts the Visual Studio development environment using the established environment. Replace the file paths shown with the correct paths for your system.
  2. Manually change all pertinent pathnames in Visual Studio's Tools..Options..Projects..Directories to include the appropriate directories from your chosen Platform SDK.
But my product is not microsoft platform SDK. I only install micro visual studio c++2005.
fqinfortran
Do I need to install microsoft platform SDK to use Fortran?
Steven_L_Intel1
No, assuming you installed enough of Visual C++.
fqinfortran
Hi, Steve.
But I cannot follow the first step because I cannot find "c:\program files\microsoft platform SDK\SetEnv.bat".
    Environment for
    "C:\Program
Steven_L_Intel1
All you need to do is open the "Fortran Build Environment" command window from the start menu. The other stuff is not necessary and would assume you've installed other things you don't need.
fqinfortran
Hi, Steve
I don't know what's wrong with my"Intel Fortran Compiler 9.1.023 build environment for EM64T-based applications".
When I click that one it just pops up this command window. But the command is
C:\Documents and Settings\me277c>
If I input command "ifortvars.bat" in that directory, it says "The system cannot find the path specified."
How can I move forward?
Steven_L_Intel1
The "build environment" window shortcut runs ifortvars.bat for you, but it should have set up PATH so that ifortvars.bat could be found (not that you should need it). Was there any other output when you first opened the command window? Are you trying to build a 64-bit application? (That's what the "EM64T" is for. Maybe you want IA-32 instead?)
That version is so old I don't have it installed anymore, so my memory may be a bit foggy, but it should display some information about the compiler and Visual Studio version when you use the Build Environment shortcut. Try the IA-32 one.
If you do want 64-bit builds, you will need to make sure that you have VS2005's 64-bit support installed. It is not the default. You may need to do a "Change" on VS2005 and add in the "x64 Compiler and tools" component.
I suggest starting with IA-32 and get that working.
mecej4
There are too many uncertain factors here. Unless I missed noting it, it has not been stated whether the Abaqus is 32-bit or 64-bit. The version that you identified (6.8) came with both 32- and 64-bit editions. Most probably, you need to use a C-compiler and/or Fortran compiler of the same bit-size and an OS that supports those compilers. The Abaqus Web site states that their 6.8 goes with VC++ 2005 and Intel Fortran 9.1 to 10.1. That gives us eight possible combinations of Abaqus, Visual C++ and Intel Fortran. You want only one of those combinations (some of the other combinations may be useful for other things, so I am not suggesting that if they exist they need to be removed).
Specifically, identify which versions of Abaqus, Visual C++ and Intel Fortran you have. One place to look for this information is under the Programs and Features item of the Windows Control Panel
Once you identify the versions, we can take things up from there as to installing Intel Fortran.
fqinfortran
Hi, Mecej4
All are 64-bit.
mecej4
Good. From the same command window from which you tried to execute Abaqus, try running
cl
and
link
If these are not found, you need to fix that problem first. Otherwise, please not the version information output from each command and let us know.
mecej4
Duplicate post. Please delete.
fqinfortran
I just input the following commands but didn't work.
c:\abaqus jobs>cl
and
c:\abaqus jobs>link
It says 'cl' is not recognized as an internal or external command, operable program or batch file.
So how to run cl and link?
Are those commands correct? What are thy if not?
Steven_L_Intel1
It means you have not established a command environment for Fortran or for Microsoft Visual C++. How did you start the command prompt session?
fqinfortran
Do you mean the command prompt session for abaqus?
I have a shortcut for abaqus command right over the "start".
Steven_L_Intel1
You need to open an Intel Visual Fortran Build Environment window and then invoke Abaqus from that.
fqinfortran
But when I try "Intel Fortran Compiler 9.1023 build environment for EM64T-based applications",
It directed me to C:\Documents and Settings\me277c>
not abaqus jobs command.
Why is that?
How to fix it?
