execution speed and CPU usage
jswaugh
Hereis a pairof perhaps naive puzzles: In a project that, among other things,manipulateslargearrays -- say, dimension (1000,1000). Comments would be welcome.
1) The release version, optimized for speed, runs no faster, give or take a couple of percent,than the debug version.
2) Task manager shows that the main program uses 25% of CPU(Xeon) time, and the remaining 75% is used by the system idle process. Paging seems minor.
jimdempseyatthecove
How many cores does your system have? If 4 then 25% = 100% of 1 core.
If you have only 1 core then something in the app is causing it to block. What does the disk read/write information indicate? What does the NIC read/write indicate? Is your app performing a lot of thread safe system function calls? (e.g. DRAND).
If your app is waiting 75% of the time for someting then run debug and perform Break All and Continue10 to 20 times checking where the program is waiting.
Jim Dempsey
jswaugh
There is one (recent) Xeon chip -- unknown number of cores. Hyperthreading is enabled. TaskMgr shows 4 CPU's. Total CPU load shows ~25% always, divided among these processors. Breakall always stops in one or another of 3 routines, all involved with diagonalizing or otherwise handling large arrays. Remainder of the time is spent in system idle process. The only disk I/O is buffered,and break never stops there. Does this help?
TimP
Putting aside minor quibbles about the distinction between Xeon and Pentium-D, if you are running a single thread on Pentium-D with hyperthreading enabled, it looks as if everything you report is normal. You might get a small performance improvement by tinkering with the task manager affinity check boxes so as to restrict execution to a single core, or a larger improvement by compiling with threading enabled, setting 2 threads, and affinitizing the 2 threads to separate cores or disabling HyperThreading.
jimdempseyatthecove
So you have a dual core Xeon with HT. Your application is single threaded. (100% of 1/4 # CPUs) You might consider using:
OpenMP and processing your arrays yourself
A multi-threaded library (MKL)
Auto-parallelization
Without seeing your app it would be hard to advise you of the route to take.
Jim Dempsey
