failed computer restore to new disk/computer, license not available
bmchenry
New Contributor II
Had disk/computer failure & restored BU clone to new disk/computer now when compiling get error below
i only use/need on this one computer is there any documentation of steps to deactivate the others so this new/replacement works?
thank you
this at end
ifort: error #10052: could not checkout FLEXlm licens
and this at beginning of build
1>------ Build started: Project: Shared_Globals_DLL 3D_2014, Configuration: Release Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler 16.0 [IA-32]...
1>mod_versionID.f90
1>Error: A license for Comp-FW is not available (-9,57).
1>License file(s) used were (in this order):
1>    1.  Trusted Storage
1>    2.  C:\Program Files (x86)\Common Files\\Intel\Licenses\COM_W__CPPFOR_RCXD-XXXXXXC.lic
1>    3.  C:\Program Files (x86)\Common Files\\Intel\Licenses\COM_W__CXXXXXXlic
1>    4.  C:\Program Files (x86)\Common Files\\Intel\Licenses\w_XXXXXX.lic
1>    5.  C:\Program Files (x86)\Common Files\\Intel\Licenses\w_XXXXXXXX.lic
1>    6.  C:\Program Files (x86)\Common Files\\Intel\Licenses\w_XXXXXX.lic
1>    7.  C:\Program Files\Common Files\Intel\Licenses
1>    8.  C:\PROGRA~2\INTELS~1\COMPIL~1\windows\bin\ia32\*.lic
1>Please visit http://software.intel.com/sites/support/ if you require technical assistance.
1>ifort: error #10052: could not checkout FLEXlm license
mecej4
Please edit your post and redact your license numbers, which should not be displayed in a public forum. If Intel personnel need the number from you, they will use private channels to obtain it from you.
bmchenry
New Contributor II
thanks for the heads up
they are all expired however understand
B
bmchenry
New Contributor II
Firgured it out! went to registration page and downloaded the license to the new machine
SOLVED!
