fatal error LNK1104: can not open “dfor.lib”
Peng_G_1
I have a FORTRAN language project which I am trying to build it with the port 3 library. I get the following error.
LINK : fatal error LNK1104: cannot open file "dfor.lib"
Microsoft Visual Studio 2012,Intel(R) Visual Fortran 2013, and windiows 7
Lorri_M_Intel
dfor.lib is the Fortran runtime library that was provided with CVF.
It seems that at least one of your objects or libraries was built with CVF, and was not re-built with Intel Fortran.
You *might* be able to get away with simply adding /nodefaultlib:dfor.lib to the link line.   However, that might provoke other undefined symbols, just to warn you.
           --Lorri
Steven_L_Intel1
Even if you don't get link errors, I very strongly recommend instead that you recompile all Fortran sources (including those in libraries or objects) with Intel Fortran, as otherwise you may get unexpected behavior.
mecej4
If the Port-3 library was built with CVF, the routines in the library will have STDCALL linkage, which is not compatible with the default linkage conventions of Intel Fortran.
Peng_G_1
How to resolve this problem?
Peng_G_1
Thanks for your help. How to  recompile all Fortran sources (including those in libraries or objects) with Intel Fortran? I rebuild all the program but the problem is still there.
Peng_G_1
           --Lorri
Thanks for your reply. Lorri
Yes, the port 3 library was built with CVF, and was not re-built with Intel Fortran. So where can I found the link line and simply adding  /nodefaultlib:dfor.lib.
Steven_L_Intel1
You are going to have to rebuild the "port 3" library or get a version that was built with Intel Visual Fortran.  While you MIGHT be able to eliminate link errors with /ignorelib, it will almost certainly lead to unexpected run-time behavior.
If you really want to try this, set the project property Linker > Input > Ignore Specific Library to dfor.lib  But don't get your hopes up.
Peng_G_1
Thanks, Steve.
Yes, eliminate link errors can not get my hopes, there are many other library link errors.
I did not get a version port 3 that was built with Intel Visual Fortran, So I have to rebuild it. Could you please tell how to rebuilt  a CVF "port 3" library with  Intel Visual Fortran. Thanks very much.
mecej4
Do you have the sources for the Port library, or at least the portions of the library that your program uses? If not, you may need to rework your program to use a more modern set of libraries such as MKL. Portions of Port are available at http://www.netlib.org/port/ , but not all portions of Port are available there. Those non-public portions had to be obtained by request from Bell Labs, but that was decades ago, and the old Bell Labs is gone for ever.
Peng_G_1
Thanks for your reply. It will be very useful to me.
