I have followed the IMSL installation instruction per
https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries
but I get the following error message when I tried to compile,
"fatal error LNK1104: cannot open file 'imslmkl_dll.lib' "
I can see this file in the folder
"C:\Program Files (x86)\VNI\imsl\fnl701\Intel64\lib"
I would appreciate your help.
Byung
Are you building a 32-bit or 64-bit application? Perhaps you didn't get the Library files paths quite right, or didn't modify both the Win32 and x64 paths. Please double-check.
Hi Steve
You were right; I had the line copied to a wrong place (for Win32, line for Include had the line for Library instead).
Thank you so much for your help!
Byung
Topic Options
