for_stop_core
martymike
In CVF and its precessors a routine named for_stop_core would be called if a STOP was encountered in the program, and we could overwrite that routine - and did. This technique does not seem to be working with IVF 9.1. Should it? I may be doing something incorrect in the build, but before I go off digging for such a problem I'd like to be sure it was supposed to work in the first place.
"Supposed to work"? No. We never documented nor supported the notion of users replacing run-time library routines. Fortran is not C.
That said, I don't spot an obvious reason why it should not work if you do it right. _for_stop_core is still the routine being used (the leading underscore being the standard name decoration and it's the same as CVF.)
martymike
Thanks Steve. Perhaps "supposed to work" was an injudicious choice of words - you've answered my question. I don't think I'm doing anything differently than I did with CVF, but it doesn't seem to be getting to that routine. I even specify CVF external calling conventions in the builds, just to eliminate one source of change. I can certainly dig harder - I just didn't want to be wasting my time if this technique just wasn't going to work anymore.
That said, is there a more standard way of capturing program termination? We track time used by users, and it's easy to find out when it starts, but a bit more problematic to find every way it can stop.
Note that the RTL routines, such as for_stop_core, use the C calling convention, even in CVF.
I'm not familiar with doing termination handlers on Windows. This MSDN article looks interesting, but it seems you'd have to write a C++ wrapper around your program to use the technique.
