Hello
I am getting the following message after running the code:
forrt1: severe (24): end-of-file during read...
What does this mean?
Basically, I'd like to sort the following column of numbers into an order based on their indices:
Example:
12
3
8
The index order is:
3
2
1
So, the expected output is:
8
3
12
What I am getting in the output file is:
12
Please could anyone help?
Thank you.
Something like this:
1 Read index file
2 Read data file
3 Output the data e.g.
do I = 1,3
do j = 1,3
if (I .eq. index(j)) then
write(33, *) data(j)
endif
enddo
enddo
It is not quite clear from your description, but I guess that you are reading the data from a file. Apparently this is not going the way you expect it - the program reaches the end of the file before it has been able to read all the data it expects to find there, hence the error message.
To help you, we will need to know more about what your program is doing. Could you post the parts that are reading the file? Include the declarations of the variables, that may be important.
Hi
Thank you for your reply.
Both data and index order are read in from text files, respectively.
The data.txt file contains a column of numbers:
12
3
8
The index.txt file contains a column of indices:
3
2
1
I would like to sort the numbers based on their indices in that particular order as in the index.txt and then write out to sorted.txt.
The Fortran code is:
program sort
implicit none
integer i, j, data(3), index(3)
open(11, file='data.txt', status='old')
open(22, file='index.txt', status='old')
open(33, file='sorted.txt', status='new')
do 101 i=1, 3
do 201 j=1, 3
read(22, *) index(j)
if (index(j) == i) then
read(11, *) data(i)
write(33, *) data(i)
go to 101
else
go to 201
end if
201 continue
101 continue
close(11)
close(22)
close(33)
stop
end
Something wrong with this code?
Any comments welcome.
Well, if there is anything wrong with the code perse, is a rather philosophical question ;). But it definitely is not doing what you want. Your code searches for the line that contains the value of i, but it does not rewind the file, so on the next value of i (loop 101), it reaches the end of the file and then you get the error message. Instead you could do:
- Read the indices
- Read the data
- Write out the data in the order given by the indices
You are already storing the data and the indices in arrays, so use that feature.
Hi
Thank you for the tips.
However, I think I am complicated myself with the following:
Please could you provide more insight?
Since the index for the data is in the array index, you can use data(index(i)) to get the value that should appear in the i-th position
Hi
Many apologies as I am still struggling with this.
Please could further help with demonstrating an example of the code?
(Beginner)
1 Read index file
2 Read data file
do I = 1,3
do j = 1,3
endif
enddo
enddo
Well, most of it is already there - you just need to read the index file in one loop and the data file in another loop. Then in a third loop you can write the data as I showed.
Instead of:
do 101 i = 1,3 ... 101 continue
you can also do (and this is preferred, because you do not need to be careful with the label numbers then):
do i = 1,3 ... enddo
Or, to make it more generic: instead of 3 as a fixed upper bound, use size() to get the right upper bound automatically:
do i = 1,size(index) read( 101, * ) index(i) enddo
Thanks guys. The code works with some small modifications and does the job. Very much appreciated!
