fortran invoking fortran dll LNK2019 problem on win7 64bit, decorate does not work
Di_C_
The code: [fortran] !foo.for #define DLLIMPORT(name) _EXCLAMATIONDEC attributes dllimport,alias:#name::name #define DLLEXPORT(name) _EXCLAMATIONDEC attributes dllexport,DECORATE,alias:#name::name subroutine FOO() DLLEXPORT(FOO) end !main.for #define DLLIMPORT(name) _EXCLAMATIONDEC attributes dllimport,alias:#name::name #define DLLEXPORT(name) _EXCLAMATIONDEC attributes dllexport,DECORATE,alias:#name::name program main DLLIMPORT(FOO) call FOO end [/fortran] compiled with ivf 2013 running on ia 32 with vs 2010. the os is win7 64bit it is compiled with option below to generate exclamation mark: /fpp /D_EXCLAMATIONDEC=!DEC$ but when link an error occured: error LNK2019: __imp__FOO dumpbin -exports foo.lib: [plain] File Type: LIBRARY Exports ordinal name _FOO Summary C0 .debug$S 14 .idata$2 14 .idata$3 4 .idata$4 4 .idata$5 C .idata$6 [/plain] dumpbin -exports foo.dll: [plain] File Type: DLL Section contains the following exports for foo.dll 00000000 characteristics 53008ECE time date stamp Sun Feb 16 18:11:26 2014 0.00 version 1 ordinal base 1 number of functions 1 number of names ordinal hint RVA name 1 0 00001000 FOO Summary 2000 .data 2000 .rdata 1000 .reloc 5000 .text [/plain]
Lorri_M_Intel
Please try adding DECORATE to your DLLIMPORT macro as well.
              --Lorri
Di_C_
              --Lorri
Dear Lorri:
Thansk a lot!
I've tried that, but the compiler says the DECORATE is conflict with DLLIMPORT.
Finally, I found the problem is caused by that I changed the target from win32 to x64, but I did not change the *.lib file the linker used... the path to the new *.lib is ./x64/Release rather than ./Release.
I should use less fixed path strings.
-Di.C.
Di_C_
              --Lorri
Dear Lorri:
Thansk a lot!
-Di.C.
Di_C_
              --Lorri
Dear Lorri:
Thansk a lot!
-Di.C.
Lorri_M_Intel
:-)  I'm glad to hear you've resolved the problem!
             --Lorri
